Electric Field Required to Accelerate Electrons in Television Tube
The required electric field to accelerate electrons in a television tube is calculated to be -1.136 x 10^5 N/C. This value is derived from the mass of the electron (9.10939 x 10^-31 kg) and its charge (-1.60218 x 10^-19 C), using the equations of motion and force. The acceleration needed to reach a final velocity of 2 x 10^7 m/s over a distance of 0.053 m is first determined, followed by calculating the force using F = ma. Finally, the electric field is found using E = F/q, confirming that the field must act in the opposite direction of the electron's motion.
  • Understanding of classical mechanics, specifically Newton's second law (F = ma).
  • Knowledge of electric fields and forces, particularly the relationship between force and electric field (F = qE).
  • Familiarity with kinematic equations, especially V_f^2 = V_i^2 + 2ad.
  • Basic understanding of electron properties, including mass and charge.
  • Study the derivation of kinematic equations in detail.
  • Learn about electric fields and forces in more complex systems, such as capacitors.
  • Explore the principles of particle acceleration in physics, including applications in cathode ray tubes.
  • Investigate the effects of electric fields on charged particles in various media.
Physics students, electrical engineers, and anyone interested in the principles of electron acceleration and electric fields in electronic devices.
pringless
The electron gun in a televeision tube is used to accelerate electrons (mass of 9.10939 x 10^-31 kg and charge of -1.60218 x 10^-19 C) from rest to 2 x 10^7 m/s within a distance of .053 m. What electric field is required?
The question only looks complicated because of the big (or small) numbers. You are given a change in velocity, a distance, and a charge.
First find the acceleration on the electron with this equation.
[tex]V_f^2 = V_i^2 + 2ad[/tex]
Now find the force on the electron with this equation
[tex]F = ma[/tex]
Now find the electric field with this equation
[tex]E = \frac{F}{q}[/tex]
To calculate the required electric field, we can use the equation F = qE, where F is the force exerted on the electron, q is the charge of the electron, and E is the electric field.
First, we need to calculate the force required to accelerate the electron to a speed of 2 x 10^7 m/s. We can use the equation F = ma, where m is the mass of the electron and a is the acceleration. Plugging in the given values, we get F = (9.10939 x 10^-31 kg)(2 x 10^7 m/s^2) = 1.821878 x 10^-23 N.
Next, we can rearrange the equation F = qE to solve for E. This gives us E = F/q. Plugging in the values for F and q, we get E = (1.821878 x 10^-23 N)/(-1.60218 x 10^-19 C) = -1.136 x 10^5 N/C.
Therefore, the required electric field to accelerate the electrons in the television tube is -1.136 x 10^5 N/C. The negative sign indicates that the electric field must be directed towards the electron gun, in the opposite direction of the electron's motion, in order to accelerate the electrons.
  • · Replies 34 ·
9K
