Solving for Distance and Angle in Baseball Press Box and Inclined Road Problems
  • Thread starter Thread starter XPX1
    Hard
The discussion revolves around two problems related to geometry and trigonometry in real-world contexts: one involving a baseball press box and the horizontal distance to second base, and another concerning the angle and distance on an inclined road related to elevation gain.
  • Mixed
  • Participants explore the relationship between vertical and horizontal distances using trigonometric functions, specifically tangent for the baseball problem. Questions arise about how to approach the second part of the inclined road problem, particularly in determining the additional distance needed for further elevation gain.
Some participants have provided calculations and attempted to clarify the relationships between the angles and distances involved. There is a mix of attempts to solve the problems, with some expressing uncertainty about the methods to use. One participant indicates that visualizing the problem through drawing triangles aids their understanding.
There are indications of confusion regarding the use of trigonometric functions and the setup of the problems, particularly in the context of the second part of the inclined road question. The original poster expresses difficulty in approaching the problems without complete information on the hypotenuse in the first scenario.
XPX1
The press box at a baseball park is 38.0 ft above the ground. A reporter in the press box looks at an angle of 16.6° below the horizontal to see second base. What is the horizontal distance from the press box to second base?
____ ft
How do you figure that out? You don't have a hypotenuse so you can't use sin and cos, so I am kinda... I am out of ideas anyone know what to do?
AND!
You are driving up a long inclined road. After 1.5 miles you notice that signs along the roadside indicate that your elevation has increased by 530 ft.
(a) What is the angle of the road above the horizontal?
°3.828 CORRECT
(b) How much further do you have to drive to gain an additional 150 ft of elevation?
____mi ?
How do I figure out part B of this problem?
the 38 ft is the vertical distance on the right angle triangle and you are trying to find the horizontal distance. So you can do tan16.6=38.0/x x=38/tan16.6 which equals roughly 127.5 ft.
#2 Sorry I don't know feet and miles
k wait Ill try it, should be 3.838 degrees for part a. Add 150 ft to y, so you get 680 ft. You know that the angle is 3.838 degrees, so draw a triangle. You're trying to find the hypotenuse. Sin3.838=680/x x=680/sin3.838 x=10159 ft. Take x and subtract the original distance. 10159-7920=2239 ft. Or Sin3.838=680/x+7920 x+7920=680/sin3.838 x=(680/sin3.838)-7920
Thanks I got it correct! It seems to help me more if I can see someone do the problem, and how they did it, instead of tidbits of information on how to set it up, thanks a lot man!
9K
  • · Replies 16 ·
