Rotation of a magnetic computer disk
The discussion revolves around two physics problems related to rotational motion. The first problem involves a magnetic computer disk accelerating and the speed of a point on its edge after a certain time. The second problem concerns the rotational kinetic energy of a system of two balls connected by a rod rotating about their center of mass.
  • The original poster seeks guidance on how to approach the problems step by step, indicating a need for foundational understanding. Some participants emphasize the importance of showing initial work to facilitate assistance. Others suggest understanding key concepts such as rotational kinematics and the definitions of rotational kinetic energy and center of mass.
Participants are actively engaging with the problems, with some providing hints and prompting the original poster to clarify their understanding. There is a mix of attempts to solve similar problems, and while some guidance has been offered, explicit consensus on methods or solutions has not been reached.
Participants note the necessity of showing work to receive help, and there are hints about the definitions and formulas relevant to rotational motion, indicating that foundational knowledge is being questioned and explored.
ada15
Hey guys, does anyone know how to approach these two problems ... can u please help me ?
Question 1. A magnetic computer disk 8.0 am in diameter is initially at rest. A small dot is painted on the edge of the disk. The disk accelerates at 600 rad/s2 for ½ s, then coasts at a steady angular velocity for another ½ s. What is the speed of the dot at t=1.0 s ? Through how many revolutions has it turned?
Question 2. A 300 g ball and a 600 g ball are connected by a 40-cm-long massless, rigid rod. The structure rotates about its center of mass at 100rpm. What is the rotational kinetic energy ?
I'll be really really thankful if you guys tell me how to approach these problems step by step.
Welcome to the PF, ada15. First of all, do not double-post your questions. I deleted your duplicate thread in the Advanced Physics forum.
Second, you must show some of your own work in order to get our help. How would you start question -1- ?
As berkeman says, you'll have to do some work on your own and show where you got stuck to get help. Here are some hints:
(1) Understand http://canario.iqm.unicamp.br/MATDID/HyperPhysics/hbase/mi.html#rlin"; this is a rotational kinematics problem.
(2) What's the definition of rotational KE? What's the center of mass? What's the rotational inertia?
I have a similar problem to this. The numbers are slightly different, though.
A 260 g ball and a 510 g ball are connected by a 37.0-cm-long massless, rigid rod. The structure rotates about its center of mass at 140 rpm.
What is its rotational kinetic energy?
Well, I know I will need to find the center of mass first.
((.260kg)(0m) + (.510kg)(.37m))/(.26kg + .51kg) = .245 m
Knowing the center of mass, then I can find I
I= (m1)(r1^2)+(m2)(r2^2)
I=(.269kg)(-.245^2)+(.510kg)((.37-.245)^2)= .024 kgm^2
Now, I am not sure where I need to go from here.
What's the definition of rotational kinetic energy?
KE= (1/2)mv^2
Samurai Weck said:
KE= (1/2)mv^2
That's translational KE. What's the corresponding formula for rotational KE?
Samurai Weck said:
KE= (1/2)mv^2
That's the kinetic energy for linear motion. What is it for rotational motion? Hint -- just as mass comes into play for linear KE, the "moment of inertia" comes into play for rotational KE...
Ooooooh. K=(1/2)Iw^2
w(omega) = 140rpm(1min/60sec)(2pi/rotation)=14.66 rad/s
Krot= (1/2)(.024kgm^2)(14.66 rad/s)^2 = 2.53 J
Thanks A LOT. This was the one problem out of my homework that was kicking my behind.
  • · Replies 22 ·
14K
