Thread Closed
Constant damping force on springsystem
Share Thread Thread Tools
Nov12-06, 10:03 AM   #1
If we consider a block of mass m attached to a spring, where the system oscillates on a table with friction f, the friction force f on the block would depend on the direction of the velocity, as
[tex] m\ddot{x} = \begin{cases} -kx+f & \text{if } \dot{x}<0\\ -kx-f & \text{if } \dot{x} > 0 \end{cases}[/tex]
If I just look at one equation at a time and solve them both separatly first, I get equations where the amplitude doesn't drop with time. But that should be the case (energy in that closed system isn't conserved). So how can I solve this system?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov12-06, 01:42 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by P3X-018
The direction of [itex] \text{f} [/itex] changes abruptly every time the velocity canges direction. You solve this by solving x(t) for every time interval that has constant [itex] \text{f} [/itex] separately. Solving for each half period separately may appear to give no change in amplitude, as if the mass were hanging on a spring in the presence of gravity, but in fact you are being fooled into thinking that is the case. The change in direction of [itex] \text{f} [/itex] every time the velocity chages direction is going to reduce the amplitude. You can find out the magnitude of this effect from energy considerations, or you can think about what a constant applied force does to the equilibrium position of the oscillator.
Thread Closed
Thread Tools
Similar Threads for: Constant damping force on springsystem
Thread Forum Replies
Constant Damping Factor General Engineering 0
How to find spring constant & damping coef of speaker flexure Introductory Physics Homework 2
Damping constant. Introductory Physics Homework 5
damping constant Introductory Physics Homework 1
How do you find the Damping Constant? (SHM) Introductory Physics Homework 11
