Pulley w/ attached weights/Linear+Angular acceleration.
The discussion revolves around determining the linear and angular acceleration of two disks connected by ropes and weights in a pulley system. The setup includes a small disk with a radius of 1m and a mass of 12 kg, and a larger pulley disk with a radius of 2m and a mass of 4 kg attached to it.
  • Mixed
  • Participants explore the relationships between linear and angular acceleration, questioning the dimensional consistency of their equations and the implications of negative acceleration values. There are attempts to clarify the setup and the assumptions regarding the directions of forces and accelerations.
The discussion is ongoing, with participants providing insights into the implications of their calculations and questioning the correctness of their methods. Some guidance has been offered regarding the interpretation of negative acceleration values and the direction of motion for the masses involved.
There is a noted lack of clarity regarding the dimensions used in the calculations, and participants are addressing potential missing information, such as the moment of inertia of the disks.
Sulla
Determine the linear and angular acceleration of the disks.
A diagram is illustrated as having a small disk (radius 1m) with a rope hanging on its edge with a mass of 12 kg attached to it. Another pulley disk (radius 2m) surrounds the smaller and first one; it has a rope attached to a 4 kg mass.
This is what I have so far:
T1 - m1g = m1a1
= t1-117.6 = 12a1
m2g - T2 = m2a2
= 2 [39.2 - T2 = 4a2]
= 78.4 - 2T2=8a2
In order to find the accel., I calculated the velocity from the radii and distance using arc length.
d2= 2(theta)
d1= 1(theta)
d2/d1= 2(theta)
d2=2a1
v2=2v1
a2=2a1
a(tangential)= (alpha)r (alpha= angular accel.)
a2=2(alpha)
2a1=2(alpha)
(alpha) = a1
T1 - 177.6 = 12a1
78.4 - 2T2 = 8a2=8*2(alpha)=16(alpha)
+ 2T2 - T1 = 4a1
___________________________________
-39.2 = 32a1
a1= -1.225
a2= 2(-1.225)
Having done that...are the objects decelerating not accelerating? And have I completed all the steps correctly?
can you show the information more clearly? i can't think of the picture
I hope this helps!
T1 - m1g = m1a1
= t1-117.6 = 12a1
m2g - T2 = m2a2
= 78.4 - 2T2=8a2
d2= 2(theta)
d1= 1(theta)
d2/d1= 2(theta) <<== theta?
d2=2a1 <<== d2 and a1 have different dimensions. This is impossible.
v2=2v1
a2=2a1
a2=2(alpha) <<== a2 and alpha have different dimensions. This is impossible.
2a1=2(alpha)
(alpha) = a1 <<== a1 and alpha have different dimensions. This is impossible.
T1 - 177.6 = 12a1 <<== dimensions?
+ 2T2 - T1 = 4a1
-39.2 = 32a1
a1= -1.225
a2= 2(-1.225)
You may have gotten the right answer, but you certainly did not do things "correctly". When you do not use units it makes it very difficult to follow your work.
If the system starts from rest it is speeding up. Whether the accelerations are positive or negative depends on the directions you chose to be positive when you set up your equations.
Assuming that up and right (y) are positive and down and left are negative (x), so the answer would still remain negative. Would that indicate that the object on the left (12 kg) is moving upwards while the object on the right (4 kg) is moving downwards? If the acceleration of both are negative wouldn't that indicated that both are moving in the same direction?
In your original equations
T1 - m1g = m1a1
= t1-117.6 = 12a1
m2g - T2 = m2a2
you identified the 12kg mass as m1 and the 4kg mass as m2. Your first equation is written as positve upward. Your second equation is written as positive downward. This is a reasonable choice, since one mass will move upward and the other will move downward. Your negative answers for both accelerations just means that in fact the 12kg mass (m1) will accelerate downward while the 4kg mass (m2) will accelerate upward. The magnitude of the static (i.e., pulleys held in place) CCW torque, 12kg*1m*g, is greater than the magnitude of the static CW torque, 4kg*1m*g, so these directions are to be expected.
I don't see how you got your answer. Do the disks have mass? Is there a moment of inertia given?
I apologise, I left out the fact that I = 4 kg m^2 .
  • · Replies 97 ·
18K
