| Thread Closed |
Ooo template...Method of image charges |
Share Thread | Thread Tools |
| Dec10-06, 05:31 PM | #1 |
Two semi-infinite grounded plane conductors that intersect at the origin, with an angle of 60 degrees between them. A point charge of q is located some distance from the origin, and bisects the angle between the two conductors, where would the image charges be and what would they be? 2. Relevant equations well you gotta know the method, I won't explain it in detail 3. The attempt at a solution Ok, here's the thing, I can solve the simpler similar problem where the conductors are at right angles(ie they intersect at the origin and run along the x and y axis, and the "vacuum" region is in the first quadrant)Based on that solution, I figure the image charges should be locacted... http://www.glenbrook.k12.il.us/gbssc...ln/u13l2f.html scroll down to the first big picture, about the middle. I figure where I1, I2, and I5 are. But really I'm a bit at a loss, if someone could poke me in the right direction. Is the problem described clearly enough? |
| Dec11-06, 06:36 AM | #2 |
Recognitions:
The 5 images look right. Just make sure they each have the right sign and add the potential from all six charges.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ooo template...Method of image charges
| Limitations of the Image Method | Introductory Physics Homework | 0 | ||
| Method of images charges | Classical Physics | 0 | ||
| Please help with image method | Introductory Physics Homework | 2 | ||
| Locating image charges | Introductory Physics Homework | 3 | ||
| Method of image | Introductory Physics Homework | 5 | ||
