Hyperbola in Cartesian Planes problem
The discussion revolves around the conditions under which a plane intersects a cone to form a hyperbola, as well as the relationship between hyperbolas and parabolas in Cartesian planes.
  • Participants explore whether the plane must be parallel to the cone's axis or simply not parallel to a generator to create a hyperbola. There is also a discussion about the classification of parabolas as special cases of hyperbolas.
Some participants affirm the correctness of the latter condition regarding the plane's orientation. There is an exploration of the mathematical definitions of hyperbolas and parabolas, with references to the general equation of a hyperbola.
Participants are discussing the geometric properties and definitions without providing specific examples or solutions, focusing instead on the theoretical aspects of conic sections.
kasse
Does the plane that intersects the cone need to be parallell to the axis of the cone to make the section a hyperbola, or is it enough that it is not parallell to a generator?
If the latter is correct, can one say that a parabola is a special case of a hyperbola?
The Latter is correct.
The hyperbola in Cartesian Planes is defined by Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0. As you Can see, a parabola is simply where B and C equals zero.
Thank you!
No problemo :)
If one takes one of the focal points of a hyperbola to infinity, then the remaining curve would be a parabola. Same is valid for an ellipse.
In other words let b tend to infinity in
[tex]\frac{x^{2}}{a^{2}}\pm \frac{y^{2}}{b^{2}} =1[/tex]
and you'll get a parabola.
Daniel.
  • · Replies 31 ·
