Calculating Current in Parallel DC Circuit - Solving for I3
The discussion focuses on calculating the current through a 12-ohm resistor in a parallel DC circuit with a total current of 2.0A. The circuit consists of three resistors: 2 ohms, 6 ohms, and 12 ohms. The voltage across the resistors is determined to be 8/3V using the equivalent resistance formula. The solution involves applying Ohm's Law (V=IR) to find the current through the 12-ohm resistor, which is directly related to the voltage across it.
  • Understanding of Ohm's Law (V=IR)
  • Knowledge of parallel resistor circuits
  • Ability to calculate equivalent resistance
  • Familiarity with basic circuit analysis techniques
  • Learn how to calculate equivalent resistance in parallel circuits
  • Study the application of Kirchhoff's laws in circuit analysis
  • Explore advanced topics in DC circuit theory
  • Practice solving problems involving multiple resistors in parallel
Electrical engineering students, hobbyists working on circuit design, and anyone interested in understanding parallel circuits and current distribution.
TheMadCapBeta
I'm having trouble solving this problem:
Three resistors(parallel) across a DC voltage source...If the total current through the circuit is I = 2.0A, what is the currect through the 12ohm resistor?
The circuit runs into a junction which splits 3 ways. Along each path there's are resistors 2ohm, 6ohm, and 12ohm, respectively, and all meet again andthen flows back to the battery.
It's parallel so I breaks up into I1, I2,I3
I found two equations:
8/3V = I1(2ohm) + I2(6ohm) + I3(12ohm)
I = I1 + I2 + I3
I found the voltage by first find the equivalent resistor for R1, R2, and R3, (R = 4/3 ohm) So V = IR => V = 2(4/3) => V = 8/3V.
I need to find the current through R3, and I could if I had one more equation, but I'm stuck. I can't see any other equations by loop rule or Kirchoff's law. So, any help will be appreciated, thanks.
I = I1 + I2 + I3
Good start!
Two words: Ohm's Law
You know the voltage across the 12Ω resistor (it's the same as the voltage of the battery). You also know the resistance, so just use V=IR and you're home free.
edit: typo
I knew I was forgetting something. Thanks.
