What is a sulfurized vegetable oil and how is it made?
  • Thread starter Thread starter JGM_14
    Oil Temperature
The discussion centers on the creation of sulfurized vegetable oil, specifically using canola oil and sulfur. The process involves melting sulfur, mixing it with canola oil, and heating until a reaction occurs, resulting in a thick, blood-red oil. This sulfurized oil has applications in high-pressure lubricants and metalworking, but its sulfur content raises environmental concerns due to regulatory restrictions on sulfur emissions. The chemical transformations include the addition of sulfur to the double bonds in the fatty acids of canola oil, potentially forming sulfide or disulfide compounds.
  • Understanding of organic chemistry, specifically fatty acid structures and unsaturation.
  • Knowledge of sulfur chemistry, including vulcanization processes.
  • Familiarity with the properties and applications of vegetable oils in industrial contexts.
  • Awareness of environmental regulations regarding sulfur emissions.
  • Research the chemical properties and applications of sulfurized vegetable oils in lubrication.
  • Explore the process of vulcanization and its effects on unsaturated fatty acids.
  • Investigate environmental regulations related to sulfur emissions in industrial applications.
  • Learn about the synthesis and characteristics of sulfide and disulfide compounds.
Chemists, industrial lubricant formulators, environmental scientists, and anyone involved in the production or application of sulfurized oils.
JGM_14
One time I made an oil that burned cooler than normal (or so I think) and has a persistent flame (in light wind it would not go out when a candle flame would). Burns better than Regular canola oil. I made it by melting sulphur in the bottom of a metal dish then pouring canola oil on top then heated until it boiled and it started to flare (little blue flames on top every time a bubble popped). Then I took it off the heat and waited until it bubbled again. Then I poured off the liquid floating on top and let it cool (if it wasn't poured out I would have had to scrape it out because it was exactly like molasses including color and viscosity but excluding smell). That was diluted consideribly with more canola oil. The final product was a blood red oil. Inital sulphur and oil volumes near a 1:1 ratio, diluted product was about a 10 to 15:1 of the regular oil to the molasses like oil. What may this possibly be?:confused:
Chemistry news on Phys.org
dunno, but sulphur turns blood red when it melts and gives off blue flames when it burns.
The unsaturated fatty acid profile for Canola oil is:
Oleic (C18:1) 53-60%
Linoleic (C18:2) 19-23%
Linolenic (C18:3) 8-12%
Eicosenioic (C20:1) 1-2%
Erucic (C22:1) 1-2%
The number in parenthesis is the carbon chain length (C18, C20, C22, for example) and the number of double bonds (unsaturation). Oleic acid has one double bond and Linolenic has three.
Since we know that sulfur adds to double bonds (vulcanization), we can surmise that this happened to some, if not all, of the double bonds in the oil. Notice that over 80% of the fatty acids that make up canola contains at least one double bond. The form of the sulfur in the crosslinked product ("like molasses" you said) may be sulfide (R-S-R) or disulfide or higher (R-SS-R, R-SSS-R, etc...). These compounds can act as a solvent for elemental sulfur which can color the oil.
The product you formed is referred to as a "sulfurized vegetable oil" and it is not new. These products find utility in high pressure lubricants and in metalworking applications. Some of the drawbacks of the process you described are that you don't know exactly the amount of sulfur added to the material and you don't know it's chemical form. These materials generally thicken with time to a rubbery mass. Dilution with base oil is possible but dilutes the benefit as well.
I don't know how well it would burn but the sulfur content would eliminate any serious use from an environmental hazard perspective. Sulfur emissions are tightly regulated in Texas, for example.
  • · Replies 29 ·
9K
  • · Replies 29 ·
  • · Replies 19 ·
11K
