How Do You Solve 2D Momentum Collision Problems?
  • Thread starter Thread starter MtX
    2d Physics
The discussion revolves around solving two-dimensional momentum collision problems in physics. Participants are exploring scenarios involving collisions where objects stick together post-collision, focusing on momentum conservation principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conservation of momentum in two dimensions, questioning how to apply linear momentum equations to two-dimensional scenarios. There are inquiries about the treatment of combined masses when objects stick together after a collision.
Some participants have offered guidance on using momentum equations in two dimensions, emphasizing the need to separate components. Others are seeking clarification on specific examples and the implications of objects sticking together after collisions.
Participants are working within the constraints of homework problems, which may limit the information provided and the methods discussed. There is an acknowledgment of the complexity introduced by two-dimensional motion compared to linear problems.
MtX
hi.. I am having difficulty solving 2D momentum-collision questions.. i can do linear ones but somehow i don't know what to do for 2D ones.. can someone please help me?
1. A 3.2-kg hawk soaring at 20 m/s [N] collides with a 0.50-kg sparrow flying at 5.0 m/s [W]. If both the hawk and sparrow are on the same horizontal plane, find their velocity if the hawk hangs on to the sparrow after collision.
2. A 3000-kg car traveling at 20 m/s [N] collides with a 5000-kg truck moving east on an icy road. The bumpers of the two vehicles become entangled and the vehicles remain joined after the collision. Calculate the initial speed of the truck if both vehicles after collision go [E 30 N].
Just remember two things: momentum is conserved, and orthogonal directions (ones at right angles to each other, such as up-down and left-right or North-South and West-East) are independent.
So that means we can split up the directions and get:
[tex]p_\textrm{x,object1,before} + p_\textrm{x,object2,before} = p_\textrm{x,objects,after}[/tex]
and
[tex]p_\textrm{y,object1,before} + p_\textrm{y,object2,before} = p_\textrm{y,objects,after}[/tex]
By the way, shouldn't this be in the homework help forum?
cookiemonster
i used that formula to solve linear questions.. but i don't know what to do for 2D ones.. can someone show me a step to step solution please? i am trying to get a clear picture of things but its so confusing..
You're going to use the same equations. Except now there will be two of them, so you'll have to go through a bit more algebra to get to what you want.
cookiemonster
can you just show me how to do one?
Let an object of mass 100kg and velocity 10m/s traveling 30 degrees South of directly East collide with an object of mass 50kg and velocity 20m/s traveling 45 degrees North of directly East.
[tex]m_1v_1\cos30 + m_2v_2\cos45 = (m_1 + m_2)v_\textrm{x,a}[/tex]
[tex](100\textrm{kg})(10\textrm{m/s})\cos30 + (50\textrm{kg})(20\textrm{m/s})\cos45 = (100\textrm{kg} + 50\textrm{kg})v_\textrm{x,a}[/tex]
[tex]v_\textrm{x,a} = \frac{(100\textrm{kg})(10\textrm{m/s})\cos30 + (50\textrm{kg})(20\textrm{m/s})\cos45}{(100\textrm{kg} + 50\textrm{kg})}[/tex]
Repeat for the y-component, keeping in mind that the first object's y component of velocity is negative.
Once you have both the x and y components, use the Pythagorean Theorem to get the total velocity.
[tex]v_\textrm{x,a}^2+v_\textrm{y,a}^2 = v_\textrm{a}^2[/tex]
cookiemonster
thanks.. i understand what you did, its just like linear ones but you add all the x-components and y-components... but for the examples i posted, the objects stick together after, so what will be the m1 and m2 (masses)? will there be two different masses, or will there just be one combined mass? for velocity, i know that since they stick together, the velocity will be the same, so i can use the same velocity notation..
When two objects collide and stick together their masses combine to form one mass
m1v1+m2v2=m3v3
so 2,3*20+0,5*5=2,7*v3
232,5=2,7*v3
v3=86,1111
thats a) m1 is hawk, m2 is sparrow, m3 is sparrow+hawk, v1 is velocity of hawk ect
its simple momentum... the momentum before collision is the same as after collision
