How do I find Capacitor rating to start / run Single phase motor
by sharper1968
Tags: capacitor, motor, phase, rating, single, start
sharper1968
sharper1968 is offline
#1
Feb10-07, 08:34 AM
P: 2
I am trying to refurbish a 1.1KW single phase motor (1445 RPM) but both start and run capacitors are missing.
How can I calculate what capacitors are required.
Motor is Rated 7.2 A (220 VAC)
Look forward to your help.
Thanks.
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
Averagesupernova
Averagesupernova is offline
#2
Feb10-07, 10:48 AM
P: 2,452
Call an industrial supplier and give them the make/model of the motor. They will set you up. Do you know why these items are missing? There is usually a good reason for it. Something else is wrong with the motor and the 2 capacitors were salvaged?
sharper1968
#3
Feb10-07, 11:33 AM
P: 2
Thanks for your reply, which unfortunately is not a lot of help in my circumstances.
I am in Malawi, Central Africa, and "industrial suppliers" are very thin on the ground. Being in Malawi is also the most likely explanation for the capacitors being missing - in Africa if you don't use it you lose it! It is of course possible that the is a problem with the motor, but I have done a few basic tests and I think it is ok. Obviously replacing the capacitors was the best place to start.
Is there not some way to calculate the likely ratings so I at least have somewhere to start with trial and error?
Many thanks.
Averagesupernova
#4
Feb10-07, 12:59 PM
P: 2,452
I'm sure there is a way to calculate it, or a typical set of guidlines for it. However, I wouldn't know what they are. I DO know that the values will be similar for simlar types of motors of a given horsepower rating and voltage. You do realize that you don't need a starting capacitor to do a few basic tests? If you have the running capacitor installed and just leave the starting capacitor out, NOT bypassed, just leave the terminals unhooked, apply power to the motor and manually spin the motor in either direction. The motor should spin up. Of course you haven't tested the starting winding, but you might look into wiring a bunch of light bulbs in parallel with each other but in series with the starting winding (in place of the capacitor). If it does start on it's own, it will not have much starting torque, but it should prove that the starting winding is good if it does spin up on its own.
dlgoff
dlgoff is offline
#5
Feb10-07, 05:50 PM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,633
Just a note. It's probably not the case here, but I have seen motors where the start windings (and capacitor) get disconnected form the circuit once the armature speed is high enough. The motor has a centrifugal switch on one of its shaft ends.
After some google searching; looks like for a 230vac motor, the start caps are 16-22uF.
Regard
Averagesupernova
#6
Feb10-07, 08:47 PM
P: 2,452
Quote Quote by dlgoff View Post
Regard
If the motor has a starting capacitor as well as a running capacitor then I am sure that the starting capacitor is switched out after a certain RPM. I assumed that was a known.
Register to reply
Related Discussions
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 3
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 0
Single Phase Motor Hoist Electrical Engineering 7
Single-phase motor; Power factor Engineering, Comp Sci, & Technology Homework 1
