Troubleshooting Ti84 Silver Edition Apps with Ticonnect and Ti DeviceExplorer
  • Context: Calculators
  • Thread starter Thread starter rock4christ
    Silver
The discussion revolves around troubleshooting issues related to connecting TI calculators, specifically the TI-84 Silver Edition and TI-83 Silver Edition, to computers using Ticonnect and various data cables. Participants share their experiences and seek solutions for connectivity problems.
  • One participant reports difficulty in connecting their TI-84 Silver Edition to Ticonnect, with the software not recognizing the device.
  • Another suggests that the issue may be related to using the wrong data cable, proposing that the gray USB cable is necessary instead of the black cable.
  • Some participants express frustration over the possibility that the included black cable may not function properly for data transfer.
  • A participant confirms that their TI-83 Silver Edition uses a gray cable and inquires whether the connection is USB or Serial Port.
  • Another participant shares their experience of previously using a TI-84 without needing software, indicating a lack of familiarity with the connection process.
  • One user mentions that support documentation suggests reinstalling USB drivers if the calculator is connected before installing Ticonnect, but they believe their drivers are functioning correctly.
Participants do not reach a consensus on the cause of the connectivity issues, with multiple competing views regarding the necessity of different cables and the effectiveness of the drivers. The discussion remains unresolved.
There are references to specific cables (gray vs. black) and their compatibility, but the exact reasons for the connectivity issues are not fully explored. Some participants express uncertainty about the functionality of the cables and the installation process for Ticonnect.
rock4christ
Ti84 silver edition help!
when i go to add apps to my calc I open Ticonnect and I go to Ti DeviceExplorer while my calc is hooked up to the black cable it came with. a select device window apears, it says COM1 and COM3 it searches, then both come up <not found> what should I do?
Computer science news on Phys.org
I believe you need to get the gray data cable, there is a difference in the grey and the black *can't remember what* but I know they handle data differently. Let me research this a bit and I will get back to you.
so it comes with a cable that doesn't work?! WTF
I have a Ti-83 silver edition, and it uses the grey cable.
Is this USB or Serial Port?
its a usb one
I didn't find much on the research, but I am pretty sure you do need to the gray USB cable instead of the black. I think when I bought mine I had to buy my cable separately but that was awhile ago. I would think that the black would work with your calculator since it came with it, but from the amount of time I have worked with the TI Calcs and connecting them with computers, I know there is a difference between the Gray and Black cable, and my Ti-83 Silver Edition Plus requires the Gray.
What I would honestly do would be to call their support line and see what they say before you go spend the money on a Gray cable.
Sorry couldn't be much more help,
Scale
I had a TI-84. I got all of my apps from my friends and never bothered dl ing the software for use on comp. Too bad someone stole my TI two days ago.
This is a link to a site with all the TI games that exist. I think.
http://www.calcgames.org/cgi-bin/files/files.cgi?action=list
This thread seems to be the top for my google search, perhaps someone can help me.
I'm having problems with my ti-84+ s.e. too. I have the latest version of Ti-connect installed and I'm using my old Silver USB cable. As far as I can tell I've got everything plugged in right, I started up Ti-connect, but its not finding my calculator. Suggestions would be appreciated.
I'm having the same problem as well with a TI-83 plus and USB Silverlink cable that I just bought. The support documentation at TI says that if you plug in the calculator and cable first before installing the software you need to manually uninstall the USB driver and reinstall it after loading TI Connect.
This isn't my problem and my drivers are fine, so any additional ideas would be greatly appreciated.
  • · Replies 20 ·
12K
10K
