Coefficient of Kinetic Friction on an Incline
The problem involves a block sliding down an inclined plane, with participants discussing the calculation of acceleration and the coefficient of kinetic friction. The incline angle is given as 31 degrees, and the block travels a distance of 3.5 m in 4.8 s under the influence of gravity and friction.
  • Mixed
  • Participants explore different methods for calculating acceleration, including using kinematic equations and Newton's second law. There is confusion regarding the role of friction in these calculations. Some participants question the validity of the formulas used and the assumptions made about forces acting on the block.
There is an ongoing exploration of the correct approach to determine acceleration and the coefficient of kinetic friction. Some participants have provided guidance on the importance of considering net forces and friction, while others express uncertainty about their calculations and the formulas applied.
Participants note that the coefficient of kinetic friction is not provided, and there is uncertainty about whether the calculated value is accurate. The discussion includes references to free body diagrams and the need to account for all forces acting on the block.
graywolf27
Here is the problem: A block is released from rest on an inclined plane and moves 3.5 m during the next 4.8 s at an angle of 31 degrees. The acceleration of gravity is 9.8 m/s^2. What is the magnitude of the acceleration of the block? what is the coefficient of Kinetic Friction Muk for the incline?
- I already identified Xinitial = 0, Vxinitial =0, distance = 3.5 m, time = 4.8 s, theta = 31
- to get the acceleration I used asubx = gsin(31) which gave me 5.05 m/s^2
But then again there is this formula Xfinal = Xinitial + Vxinitial*t +0.5at^2 which at the end becomes a=2distance/t^2 giving me a value for a=0.304 m/s^2 and this is the point were I get confused :frown: .
- For the coefficient of Kinetic friction, I used free body diagrams which gave me a formula of Mk=mgsin(theta)/mgcos(theta) then Mk=tan(theta) I substituded Mk=tan(31) and got an answer of Mk=0.601
Am I on the right track? Any help will be appreciated :)
Your acceleration is wrong, because you didn't take in account friction. Start from Newton's 2nd Law.
Basically I have the wrong formulas then... I found out, by re-reading my book that the Fnet = m*a in Newton's Second Law which means that I have to find first the Net Force? I already have the value for mass = 9Kg and the acting forces are the ones who make the object move? Because according to my problem, it starts moving from rest which mean that only the object's mass affected by gravity makes the force I got confused...
and the kinetic friction value is not given also, and I don't know if the one I got is right Mk=tan(31) Mk=0.601
Are you familiar with the concept of Free Body Diagram and Newton's Laws?, you are just pluggin numbers in formulas...
yeah I have the hang of free body diagrams but I still get confused... I already found the Mk = 0.56 and I'm missing the acceleration of the object. By using the free body diagrams I got Fy= mgsin(theta)+Mkmgcos(theta) =ma then I got for a= gsin(theta)+Mkgcos(theta)
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 33 ·
