Register to reply
Potential Difference of Capacitors
Share this thread:
AdKo
#1
Feb18-07, 01:50 AM
P: 19
A parallel-plate capacitor has an area of 5 cm^2, and the plates are separated by 1mm with air between them. The capacitor stores a charge of 400pC. a) What is the potential difference across the plates of the capacitor? b) What is the magnitude of the uniform electric field in the region between the plates?
2. Relevant equations
1. [tex]U_{c}=\frac{1}{2}C(\Delta V)^2[/tex]
2. [tex]C=\epsilon_{0}\frac{A}{d}[/tex]
3. The attempt at a solution
a) Using equation #1, [tex]\Delta V=\sqrt{\frac{2(400*10^-12C)}{(4.425*10^-10F)}}[/tex]
V=1.3446 V ... however, the answer in the back of the book is: 90.4 V
What am I doing wrong here? I'm pretty sure I'm using the right equation.
b) E=V/d I plugged in the book's answer for V and used the given distance to find the electric field magnitude. Help me on part a please? Thanks!
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
hage567
#2
Feb18-07, 09:55 AM
HW Helper
P: 1,539
Your first equation listed doesn't make sense for this problem. That is the equation for the energy stored in a capacitor, which you don't know (U does not equal the charge). Try to find a simplier equation containing the three things you know.
For your calculation of C using equation 2: You answer isn't quite right. I suspect you didn't convert the area from cm^2 to m^2 properly.
AdKo
#3
Feb18-07, 11:45 AM
P: 19
Quote Quote by hage567 View Post
thanks for all your help. I solved by using C=Q/V that was easy.
Register to reply
Related Discussions
Potential difference across capacitors, can someone check this? Introductory Physics Homework 1
Potential Difference and Potential Near a Charged Sheet Introductory Physics Homework 1
Electric potential, potential difference, and potential energy Introductory Physics Homework 2
Difference in capacitors Electrical Engineering 5
Capacitors and Potential Difference Introductory Physics Homework 1
