An inhomogenous equation-help
  • Thread starter Thread starter mremilli
The discussion revolves around solving inhomogeneous partial differential equations (PDEs), specifically the Poisson equation and a second-order ordinary differential equation (ODE) with non-homogeneous boundary conditions. Participants are exploring various methods to approach these equations, including the use of Fourier series and transformations.
  • Mixed
  • Participants discuss the setup of the Poisson equation and its boundary conditions, questioning how to handle the non-homogeneity. Others suggest rewriting the equations or using specific substitutions to simplify the problem. There is also exploration of the relationship between arbitrary constants in solutions and their implications.
The discussion is active, with participants providing hints and alternative approaches. Some express uncertainty about their progress and seek clarification on specific steps or concepts. There is a mix of interpretations and methods being considered, indicating a collaborative exploration of the problem.
Participants note the complexity of the equations and the challenge posed by the non-homogeneous boundary conditions. There is mention of potential confusion due to thread mixing, which may affect the clarity of the discussion.
mremilli
poisson equation with non homogeneous B.C.
hello,
I am having some trouble to solve a problem and I was wondering if someone could give me a clue. The problem is the following:
u,xx+u,yy=xy , 0<x<1, 0<y<1
BC:
u,x(0,y)=0 & u(1,y)=y for 0<y<1
u(x,0)=0 & u(x,1)=-x for 0<x<1
the equation is non homogeneous and so are the B.C.'s
thanks in advance
-marcel
Can anybody help me with this inhomogenous equation : y''=A-B(y')^2
A and B are constants.
Thanks for reading.
Let z=y', and solve for z first.
Thanks for fast answer.
I have tried like that, but it seems...not finished. Could you write down some more details?
What did you get for z?
Or did you, perchance, not finish even that part of your task?
arildno is perfectly correct in his suggestion. If, however, you are not fond of it, you can try a similar one, i.e.,
[tex]y^{\prime} = \frac{1}{B} \frac{u^{\prime}}{u}[/tex]
this will give you
[tex]\frac{1}{B} \frac{u^{\prime \prime}}{u} - \frac{1}{B} \frac{u^{\prime 2}}{u^2} = A - \frac{1}{B} \frac{u^{\prime 2}}{u^2}[/tex]
leaving you with
[tex]u^{\prime \prime} = AB u[/tex]
which should seem familiar to you.
Incidentally, to further arildno's point -- if you show us your working-out when you get stuck, we will have more chance of helping you.
Thank you very much Mathrew and Arildno. I do not know if this type of equation is easy for people in this forum, but for me, at least by now, it is not. Hope after some time , I will get improved.
Just out of curiosity, why are you refusing to post what you have done?
OK, It’s nice if you can have a look and check for me.
From the hint of Matthew, I can rewrite the following:
u''= ABu with y'=u'/(Bu)
==> u''-ABu=0. Let u=exp(kt)
then we have: k^2exp(kt)-ABexp(kt)=0
==> k^2-AB=0.==> k=+-sqrt(AB) I just investigate A>0 and B>0
So the general solutions of u is :
u=C1.exp(sqrt(AB).t) + C2.exp(-sqrt(AB).t) with C1 and C1 are arbitrary constants.
Let k=sqrt(AB)
Then y'=u'/(Bu)={C1.k.exp(kt) - C2.k.exp(-kt)}/{B*(C1.exp(kt) + C2.exp(-kt))}
Integrate 2 sides :
y=(1/k)*{ln[C1.exp(2kt)-C2]-kt} +C3
Hope that I did not make any mistake. I am not sure adding of the arbitrary C3 is correct. This is a second order equation.
How about doing homogeneous solution plus particular solution.
Then, do Fourier series to solve the boundary value problem. You have to compensate for the added particular solution when doing the FS.
Finding a part. sol'n. is sort of easy by the symmetry of the PDE. In fact there are lots of choices for the part. sol'n. Some more may be more convenient than others.
Err...looks like you may have got something slightly wrong there. If
[tex]u(t) = C_{1}e^{kt} + C_{2} e^{-kt}[/tex]
where [tex]k=\sqrt{AB}[/tex]
then, as
this means that you can also write y as
[tex]y(t) = \frac{1}{B} \ln{|u(t)|} + C_{3}[/tex]
where [tex]C_{3}[/tex] is another constant (just integrate the [tex]y^{\prime}[/tex] equation, and you'll see).
So, your final solution is
[tex]y(t) = \frac{1}{B} \ln{|C_{1} e^{kt} + C_{2}e^{-kt}|} + C_{3}[/tex]
Oh, it's just simple. It took me quite a time to integrate the funciton y', and there's mistakes ! Thanks again.
Hi,
Can anyone explain for me why this solution has 3 arbitrary constants. Is there anything special here? I have tried to solve in Matlab, the result has only 2 constants.
Whose thread is this anyway?
mremilli said:
hello,
BC:
thanks in advance
-marcel
Wasn't this Marcel's thread? That's whose Q I was addressing.
:smile:
There must be something wrong here. This thread named "An inhomogenous equation-help !" surely was posted by me. I do not understand why it is mixed with the thread by mremilli, who posted long before me. I might have made a mistake when posting this one mightn't I?
Whatever happened to mremilli's question?
mremilli said:
hello,
BC:
thanks in advance
-marcel
The fact that the equation is not homogeneous is no big deal but it will simplify a lot if you find a function that satisfies just the boundary conditions. Subtract that from u to get a differential equation that is still non-homogeneous but does have homogeneous boundary conditions. You can then write the solution as a Fourier sine series.
That's what I was answering back in 2/24
:rolleyes:
More
Try Pinsky's book PDE's and BV Prob's w/ App's
