Thread Closed
Inertial and Non-Inertial Frames of Reference Question
Share Thread
Mar12-07, 01:18 PM   #1
Exclamation
A rubber stopper of mass 25g is suspended by string from a handrail of a subway car travelling directly eastward. As the subway train nears a station, it begins to slow down, causing the stopper and string to hang at an angle of 13 degrees from the vertical. What is the acceleration of the train? Determine the magnitude of the tension in the string.
The attempt at a solution
Tension of String = (mass)(9.81) / cos 13 degrees
The Horizontal component of Tension = [(mass)(9.81) / cos 13 degrees] sin 13 degrees = (mass)(acceleration)
a = [[(mass)(9.81) / cos 13 degrees] sin 13 degrees] / mass
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Mar12-07, 01:24 PM   #2
Mentor
That works. But simplify that answer!
Mar12-07, 01:26 PM   #3
I'm not sure how to simplify the answer because I do not have many values to use...
Mar12-07, 01:28 PM   #4
Mentor
You have everything you need.
Cancel what can be canceled; use a single trig expression. Then evaluate to get the numerical answer.
Mar12-07, 01:31 PM   #5
Thank you very much! =D It took me a while to understand it.. I thought what I was doing was wrong.
Mar12-07, 01:34 PM   #6
Mentor
Your solution is fine!
FYI, here's how I would do it:
Horizontal forces:
[tex]T\sin\theta = ma[/tex]
Vertical forces:
[tex]T\cos\theta = mg[/tex]
Combine (divide one by the other) to get:
[tex]a = g\tan\theta[/tex]
Mar12-07, 01:43 PM   #7
Oh, thanks! I really appreciate your help.
Thread Closed
Similar discussions for: Inertial and Non-Inertial Frames of Reference Question
Thread Forum Replies
inertial frames of reference Introductory Physics Homework 0
Inertial Reference Frames Introductory Physics Homework 1
inertial frames of reference General Physics 5
inertial reference frames General Physics 2
inertial reference frames Special & General Relativity 2
