Proving slope m of a secant connecting two points of the sine curve
The discussion revolves around proving the slope "m" of a secant line connecting two points on the sine curve, specifically focusing on the expression for the slope and its derivation using trigonometric identities.
  • Participants discuss the formula for the slope of the secant and explore the relationship between sine values at different points. There are inquiries about standard trigonometric identities and their application to the problem. Some participants share their attempts at solving the limits involved in the exercise.
The conversation includes various attempts to clarify trigonometric identities and their implications for the problem. Some participants have successfully derived parts of the solution, while others are seeking further clarification on specific limits and expressions. There is an ongoing exploration of the limits as X approaches Xo.
Participants note that Xo and X are points on the sine and cosine curves, with constraints that they do not exceed pi/2. There is mention of the need for hints and guidance as participants work through the limits and expressions related to the problem.
Rukawa0320
Proving slope "m" of a secant connecting two points of the sine curve
Write and expression for the slope m of the secant connecting the points Po(Xo,Yo) and P(X,Y) of the sine curve. Use the appropriate trigonometric identity to show that m= sin((X-Xo)/2)/((X-Xo)/2) * cos ((X+Xo)/2)
Could somebody give a hint how to do the second proof? m= sin((X-Xo)/2)/((X-Xo)/2) * cos ((X+Xo)/2)
Basically what i need to prove is that:
(Sin(Xo)-Sin(X)) / Xo-X = sin((X-Xo)/2)/((X-Xo)/2) * cos ((X+Xo)/2)
I could manage to do the first part of the exercise, as far as now I got a formula which is the following:
m= (Yo-Y)/(Xo-x) = (Sin(Xo)-Sin(X)) / Xo-X
and the expression (Sin(Xo)-Sin(X)) / Xo-X is equal to m
Can you find a formula for sin(a)-sin(b)? It's pretty standard.
Do you mean sin(A-B) = sinAcosB - cosAsinB ?
That's related, but I really do mean sin(a)-sin(b). Look at an extensive table of trig formulae.
Or if you want to prove it from scratch, add or subtract your formulas for sin(a+b) and sin(a-b).
oohhh, i found the formula in my exercise book, it was really that standard
thank you for your help, now I am doing the (b) part of the exercise about their limits
May I ask for your help if i get stuck?
Im doing the (b) part of the exercise, which ask about what do they approach as X approaches Xo (their limits)
1)sin((X-Xo)/2)/((X-Xo)/2)
2)cos ((X+Xo)/2)
3)m(=sin((X-Xo)/2)/((X-Xo)/2) * cos ((X+Xo)/2)
Note: Xo an X are points on the cos,sin curve which is not bigger than pi/2
I was able to solve the first one, I got as X approaches Xo it will approach 1.(I think I did right, but please tell me if it's wrong)
I got stuck in the second one, could you guys give me some hint to solve the 2.?
In the thrid I guess all I need to do is to multiply the two limits (1. and 2.) and that's it.
Any helps appreciated
The second one is MUCH easier than the first one. X -> X0. No fancy limits to take really. The answer is a function of X0 - it's not a constant like the first one, if that is what is throwing you off.
I don't really understand what you mean, could you please explain it in details?
What's the limit of cos((x+2)/2) as x->2?
isnt it approaches 1?
Nope. As x->2, cos((x+2)/2)->cos((2+2)/2)=cos(4/2)=cos(2). Why 1?
But don't you need to take the cosine of two?
I could, but it isn't 1. cos(2*pi)=1, not cos(2). Do you agree the answer is cos(2)?
I see what you mean, that (2) is in radian and not degrees, thus the answer to the original question is (cos(Xo))/2 right?
It's cos((X0+X0)/2), but that doesn't simplify to what you wrote.
Im getting a lost a little bit, is it actually approaches zero?
So am I. Explain how you got cos(X0)/2?
oooh if x-->Xo therefore is it (cos(2*Xo))/2?
You are still being sloppy. The '/2' is INSIDE the cosine - not outside.
than its simply cosXo
if I multiply it with the limit of 1st one :1 than the limit of m approaches cosXo?
Yes. You just differentiated sin(x).
wow, it feels great when you finally solve something which you work on for a long time
thanks for your help!
  • · Replies 23 ·
