Solve (A+Bh)/(2B + A/h)=X to Find A
  • Thread starter Thread starter strokebow
    Rearrange
The discussion revolves around the algebraic manipulation of the equation (A + Bh) / (2B + A/h) = X, with the goal of isolating the variable A. Participants are exploring the steps necessary to rearrange the equation and are considering the implications of their approaches.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for rearranging the equation, including cross-multiplying and isolating terms involving A. Some express confusion about specific steps, while others suggest breaking down the problem into manageable parts.
There is an ongoing exchange of ideas, with some participants offering hints and guidance on how to approach the problem without providing direct answers. Multiple interpretations of the problem are being explored, particularly regarding the isolation of A versus h.
Some participants note that the problem may lead to a quadratic equation, which adds complexity to the discussion. There is also a mention of homework guidelines that discourage simply providing answers, emphasizing the importance of understanding the process.
strokebow
Hey,
I've spent ageees trying this . . .
Re-arrange to find A:
* / indicates division
I would post my attempts although it would take me a while to do s and it probably wouldn't give anyone any insight.
I'd much appreciate it if someone could re-arrange that to for me to find A please.
Thanks
What did you try? At least post an attempt at a final answer so we can maybe get an idea of what you're doing wrong. I could give you the answer, but that doesn't help you learn how to do it for next time. The steps to solving this are cross-multiplying, expanding, grouping like terms, and then isolating A. Which part do you think is causing you the most difficulty?
What did you do after you multiplied both sides by (2B+A/h)?
strokebow said:
Hey,
Thanks
We're not going to simply give you the answer! What have you tried? If I were solving this, I'd make the 1/h in the denominator go first, then multiply the whole equation by the denominator of the LHS...
I won't give you the answer (you know we won't), but I'll give you hints for the first few steps.
Get rid of the fraction on the left by multiplying both the left and right hand sides by the denominator of the fraction.
Multiply out the RHS (right hand side). That is, distribute X into the two terms in the parenthesis.
Now you want to gather up terms that have the A in them...
Do those steps here so we can see how you do. If you get that far, you'll probably see the final steps on your own, but we can help more at that point if you need it.
Holy Smokes! Homework Helper pile on! :biggrin:
Some Help
The guidelines of the help section specifically state that people are not supposed to just answer questions but rather give help instead. So, here is some help.
Step1: Combine 2B + A/h into a single fraction.
Step2: Divide A + Bh by the fraction you just obtained. (remember A + Bh can be written as (A + Bh)/1, and that to divide a fraction by a fraction you can flip the bottom and multiply.
Step3: This fraction answer is = to X
Step4: Multiply both sides by the entire quantity of the denominator.
Step5: Bring everything with an A to one side of the equation and everything else to the other side.
Step6: Factor out the A on the one side.
Step7: Divide both sides by the remaining quantity you just separated the A from, and you have your answer.
Good Luck.
Sorry . . . I meant to say re-arrange for h. I want to isolate h.
Thanks
So, what have you done so far? :smile:
Thanks
Berkeman's advice still works. Replace A in the third step with h.
yeah but the answer comes out as a quadratic
son of a gun, so it does.
I assume you had something like
A + Bh = 2Bx + AX/h
and you multiplied everything on both sides to get rid of h in the denominator.
[tex]Ah + Bh^2 = 2BXh + AX[/tex]
And, you're solving for h.
No problem... How would you solve this equation for h:
4h^2 + 3h - 17 = 0?
Solve this equation the same way: (3m)h^2 + (5+w)h + (r-t) = 0
Now, can you put the equation you had with h^2 into the form of a quadratic equation and solve it?
There's also another method called "complete the square" that would work. In fact, that method is used to derive the quadratic formula, so the quadratic formula is, more or less, a short-cut (sort of). Then again, knowing both methods, sometimes the quadratic formula works out much more quickly, and sometimes, completing the square works out much more quickly. They're both good tools to have in your arsenal of attacking problems.
So, do you know how to use the quadratic formula to solve a quadratic equation?
Thanks ppl!
Much appreciated. I can do it from here
thanks
  • · Replies 18 ·
