Line Integrals: Evaluating with Respect to Arc Length
The discussion focuses on evaluating the line integral of the function x*e^y with respect to arc length along the unit circle from (1,0) to (-1,0). The integral is parameterized using x = cos(theta) and y = sin(theta), leading to the integral of cos(theta) * e^sin(theta) dtheta. The conclusion drawn is that the integral evaluates to zero due to the odd symmetry of the function with respect to the y-axis, confirming that the integral over a symmetric domain results in zero. An alternative approach from (0,-1) to (0,1) is suggested to illustrate the non-zero result due to the lack of symmetry with respect to the x-axis.
  • Understanding of line integrals and arc length
  • Familiarity with parameterization of curves
  • Knowledge of odd and even functions in calculus
  • Experience with substitution methods in integration
  • Explore the concept of line integrals in vector calculus
  • Learn about parameterizing different curves for integration
  • Study the properties of odd and even functions in calculus
  • Practice integration techniques involving substitutions
Students and professionals in mathematics, particularly those studying calculus, vector calculus, or anyone interested in understanding line integrals and their properties.
wubie
Hello,
I must be having some sort of brain malfunction or something. First here is my question:
Evaluate the line integral with respect to arc length
The integral sub C of x*e^y ds where C is the arc of the unit circle from (1,0) to (-1,0) traversed counterclockwise.
Now if the circle is traversed counterclockwise then
-1 <= x <= 1 and 0 <= y <= 1.
I can parameterize the equation by noticing that
x = cos theta and y = sin theta.
Therefore the integral becomes
The integral of cos theta * e^sin theta ds
where ds is
( (-sin theta)^2 + (cos theta)^2 )^1/2 = 1
So the integral becomes
The integral of cos theta * e^sin theta dtheta.
Since the unit circle is traversed counterclockwise the angle goes from 0 to pi.
If I let sin theta = u then du = cos theta and the limits become zero and zero.
So if I integrate the integral of e^u du then I get
e^u with the limits of 0 and 0 which ends up to be zero.
This cannot be right can it? I am confused. I think I did everything correctly. Where am I going wrong?
Perhaps I am right?
Any help is appreciated. Thankyou.
Looks right to me, but then I've always sucked at path integrals, so. Maybe Matt will grace you with his presence.
It actually kinda seems right, too. It's an odd function with respect to the y-axis, and since we're going from -1 to 1, we have a symmetric domain. That suggests an answer of 0.
cookiemonster
Yes, that's exactly right. "xey" is an odd function with respect to x and since the path of integration is symmetric with respect to the y-axis the integral is 0.
If it makes you feel better, you might try looking at exactly the same problem from (0,-1) to (0,1) instead. You get exactly the same integral except that theta now runs from -pi/2 to pi/2. Since you are making the substitution u= sin(theta), you integration will be from
-1 to 1 giving a non-zero result. That is, of course, correct since the function is not symmetric with respect to the x-axis.
