Computer Freezing Issue: Solutions for Windows XP
  • Thread starter Thread starter LightbulbSun
    Freezing
The discussion revolves around troubleshooting a computer freezing issue specifically related to a Windows XP operating system. Participants explore various potential causes and solutions, including hardware and software considerations, as well as power management settings.
  • Some participants suggest that the freezing could be due to virus or spyware overload.
  • Others propose that CPU or system overheating might be a cause.
  • Faulty system or graphics RAM is mentioned as a potential issue by some contributors.
  • Several participants highlight the possibility of a faulty screensaver or hard drive affecting performance.
  • One participant recommends using a Linux LiveCD, such as Knoppix, to test hardware functionality without Windows interference.
  • Another suggests using MEMTEST86 to check for RAM issues.
  • Participants discuss the importance of checking for malfunctioning drivers and performing virus and spyware scans.
  • There are suggestions to disable unnecessary startup programs and check for overheating components.
  • Some participants outline a series of troubleshooting steps, emphasizing the need to monitor temperatures and listen for unusual noises from fans.
  • One contributor mentions the Microsoft Knowledge Database as a resource for identifying known issues related to symptoms described.
Participants generally agree on the need to explore multiple potential causes for the freezing issue, but there is no consensus on which specific cause is most likely or how best to address the problem. Various troubleshooting steps and methods are proposed, indicating a range of opinions on effective solutions.
Some participants note that certain steps may not be necessary for all users, and the effectiveness of suggested solutions may depend on specific hardware configurations and software environments. There is also mention of the possibility of known glitches that may not be easily diagnosed.
LightbulbSun
My girlfriend's computer is incessantly freezing, or when it does function it will freeze the minute you go idle for about 20 minutes. It's irking her and I was wondering what the cause of this is and how to fix it?
She has a Windows XP operating system.
Computer science news on Phys.org
I would consider the following causes:
1) Virus/Spyware overload.
2) CPU/System Overheating.
3) Faulty System/Graphics RAM.
I would add these possibilities... possibly related to power management:
4) faulty screensaver
5) faulty hard drive or CD ROM drive
I'd boot Knoppix ( a Linux LiveCD ). If there are no problems after (say) an hour of use, then the hardware is probably okay... and I'd look for faulty Windows settings, drivers, or files or some other software.
To test the RAM, I'd boot MEMTEST86 (free download, then burn to a CD... older versions fit on a floppy).
I'll check all five of these possibilities, but could you also give me a quick remedy for each of these five possible causes? Thanks for the information guys/gals.
What would you consider faulty Windows settings, drivers, or files etc.?
The Microsoft Knowledge Database (KDB) is often helpful in tracking down a problem based on the symptoms and the machine. Maybe give it a try:
http://support.microsoft.com/search/
I had a similar problem with my old work ThinkPad -- it would hang if the screensaver kicked in wrong. A real pain. The Microsoft KDB let me know it was a known problem, and required an upgrade in software to fix.
This is what I would do if I were you (I tried to write the steps in order of likelyhood, also as you go along, if you notice anything amiss, google the problem to learn more about it and your possible solutions. Also, bear in mind that it could be some kind of weird, known glitch that you will not be able to figure out using common sense.):
Note: You will most likely not have to complete all of these steps!
1. Disable any screen saver you might have loaded and if there has been any overclocking one on the computer, write down the settings used on a piece of paper, put it in a safe place, then reset the settings to factory defaults in BIOS. Restore the settings if this doesn't solve the problem of if it introduces new ones on top of the old problem.
2. Feel the side of the computer, is it getting hot? If so, go into the bios (or better yet, if your motherboard supports it, run a fan speed/temperature monitoring for your motherboard while windows is in use) and look at the temperatures. Do you hear any whirring noises? Maybe one of the bearings or sleeves has gone bad in one of the key fans. If this is the case, replace the fan. If you have to replace the CPU fan, look into getting some good thermal grease while you're at it to use. (of course, make sure that if you are using thermal grease, you do it properly - research how to do this)
3. If it isn't a heat issue, maybe the RAM is going bad. Download a knoppix live cd (or Mepis, or morphix. Any of these will work). They normally come with a memtest in the boot loader screen. Run this for a few hours to check for errors. Also feel the side of the computer periodically as the test runs. If there are errors, replace the RAM. (Make sure the RAM you buy will be compatible with the motherboard) If there aren't any errors, then run linux for a while. Play some games on it, talk on gAIM, make a few spreadsheets, play some music, whatever. You can also try running windows in safe mode. If it doesn't freeze, then this indicates that there is probably a software, driver, or hard drive problem (if the linux live cd doesn't crash, but windows safe mode does, then your hard drive may be going bad. Listen for some clicking noises). If it does freeze for both a live linux cd AND windows safe mode, skip to step 5. It's probably a hardware problem.
4. If the first two steps haven't solved anything, then perhaps you have a software issue. First, determine if the computer is locking up whenever you have a certain program running in the background. If so, then reinstall that program. If it still gives you problems, uninstall it and forget about it. If there's no rhyme or reason to the lockups, then it's still possible that the CPU, motherboard, graphics card, LAN card, or anything could be going bad, but it's much less likely. Second, I recommend you go to your "Device Manager," and check for any malfunctioning drivers and then reinstall any ones that are. This may sound a bit odd, but I've had this happen before. Then run a thorough virus scan, spyware scans, and a registry cleaner, rebooting as necessary. (I'd recommend using the following free programs: Avast (anti-virus), Spybot - Search & Destroy (anti-spyware), AdAware SE Personal (another anti-spyware), Microsoft Defender (yet another anti-spyware; use all three, because one will catch things that the other won't), and CCleaner (Registry cleaner)). Then run msconfig and in the "startup" tab, disable everything except the essentials, such as anti-virus, firewall, and anti-spyware (if unsure about an entry, google it before disabling it or leaving it enabled!). Also, if you aren't running a firewall, it's possible that some script kiddies have identified your computer as vulnerable and are attacking it. (I recommend using the free version of ZoneAlarm)
5.If your problem still isn't solved, or you are having trouble completing the steps, then it may very well be your hard drive, motherboard, graphics card, or anything else. I've had a few LAN cards go bad, which caused system instability. I've also had a cd-rom go bad, a graphics card, a motherboard, a hard drive.. etc.. The moment I took the offending piece of hardware out, it fixed the problem. Try removing all unnecessary components, such as tv tuners, sound card, firewire reader, LAN cards, etc, etc, then run windows and test it some more. If windows locks up, try safe mode, and then if that locks up the linux live cd (there's no need to run the memtest twice though). If the linux live cd locks up, then proceed to step 6, otherwise, it's probably your hard drive. Use a different hard drive that has an operating system on it on your computer and try to get it working.
6. Find some free computer stress testing utilities (a benchmarking program might work as well, since it will cause your computer to stop working once you start it for whatever the affected component is). Run the test on your Hard Drive, Graphics card, and then CPU. If there are any problems with any of these, the program will either alert you or will lock up shortly after you begin a test (I say to test the hard drive still, because a failing hard drive will sometimes only have problems here and there).
7. This is the last resort, besides buying a new computer or swapping out core components of your system, such as the graphics card, motherboard, or CPU. If the problem still isn't fixed, locate your recovery cds for the computer or your copy of windows. Back up any important data (settings files, mp3s, pictures, game saves, etc, etc), write down what programs you have installed, then format your hard drive, reinstall windows, and reinstall your programs. Be CAREFUL not to accidentally forget not to backup something very important.
8. If you haven't been able to fix the problem or at least diagnose it at this point, then go buy another computer, lol. (or, if you've had some interesting, yet confusing observations while going through this process, contact me and maybe we can brainstorm on the problem.)
Thanks so much. My girlfriend's grandmother made the computer for her and she told her to defrag the hard disk so she's going to see if that will fix it. If not, I'll try these steps. I think it's a faulty screensaver.
You're welcome. :)
Actually, I forgot to mention a few things, believe it or not. Also, you should have mentioned that the computer was built by her grandmother! lol.
There are certain features that motherboards have which can cause system instability.
The CAS timings for the RAM might be set too high, try relaxing them a bit. (If they are set to "2 3 3 7," try "3, 4 ,4 10." Make sure to set it back to the original settings if this doesn't fix the problem though.) When the computer was built, the motherboard may have incorrectly detected what settings it should use. This is a common occurrence when building computers.
The grandmother may have also put slower RAM into that the motherboard doesn't support at higher speeds (such as cheap DDR266 RAM), and then set the speed too high. It's also possible that the RAM she used is incompatible with the motherboard. Some RAM will only function at certain voltage levels, but some motherboards cannot produce that voltage level, so the RAM may function but will be very unstable. Has the computer been unstable from the get-go, or is it just becoming unstable? If it's been unstable since it was built, find out what motherboard was used and see if there is any RAM that does not work with it.
Try going through the bios and see if the advanced settings have descriptions, some are optional features that can speed up performance, but will sometimes cause problems with other hardware.
And one last possibility. If the grandmother built the computer, she may have damaged hardware while doing so. If she got skin oil on the circuits, didn't put the FAN onto the CPU properly or used too much (or not enough) CPU thermal grease, shocked the motherboard, etc, etc, then the computer will either be unstable from the beginning or might begin to become more and more unstable until it completely fails. I hope this isn't the case for you, but if it is, then you will have to focus on testing the individual hardware parts in another computer that has no problems.
If you try everything that I've told you here, don't blame me for wasting your time. Once I spent 2 days swapping out hardware, searching for the problem with a computer that would not boot and was giving symptoms of hardware failure. Finally, out of sheer frustration, I unplugged my logitech mouse and tried booting. It was the mouse. The damn mouse. I'd never have expected that mouse failure would prevent my computer from getting past the RAM check.
Aren't computer problems fun?
  • · Replies 20 ·
