Acid/Base Equilibria (hard, i think).
  • Thread starter Thread starter jajahaha
    Equilibria Hard
The discussion focuses on calculating the equilibrium concentrations of HSO4 and NH3 in a solution prepared by dissolving 1 oz of 80% pure Ammonium Sulfate ((NH4)2SO4) in 1 gallon of water at 25 degrees Celsius. The participant successfully calculated the molarity and equilibrium amounts for part (a) but struggled with part (b), which involves adjusting the pH to 7.0 using pure NH3 and H2SO4. It was established that to achieve a neutral pH, equal concentrations of H3O+ and OH- must be maintained, as both a strong acid and a strong base will yield nearly equal concentrations in solution.
  • Understanding of acid-base equilibria and pH calculations
  • Knowledge of molarity and how to convert between grams and moles
  • Familiarity with the dissociation of (NH4)2SO4 in water
  • Basic principles of Le Chatelier's principle in chemical equilibria
  • Learn about calculating equilibrium concentrations in acid-base reactions
  • Study the properties and calculations involving strong acids and bases
  • Explore the concept of pH and its relation to hydronium and hydroxide ion concentrations
  • Investigate the application of Le Chatelier's principle in adjusting chemical equilibria
Chemistry students, educators, and anyone involved in laboratory work related to acid-base equilibria and solution preparation.
jajahaha
1 oz of 80% pure (NH4)2SO4, 1 gallon of water @ 25 degrees Celsius.
1 gallon = 3.785 L, 1 oz = 28.4 grams.
Suppose an avid gardener prepares a solution by putting 1 oz of 80% pure Ammonium Sulfate in a gallon of water at 25 degrees C.
a) what is concentration of HSO4 and NH3 in solution at equlibrium.
b) suppose you want to make sure pH is at 7.0. If you have pure NH3 and H2SO4 at hand, how many grams (of which one) would you have to add?
(NH4)2SO4 dissolves in water to form 2NH4+ and SO4(2-)
NH4 + H2O => H3O + NH3
SO4 + H2O => OH + HSO4
i already finished part a by first changing oz and gallons into moles/L => Molarity. then i calculated equilibrium amounts by initial, change, end calculations.
my main problem lies in (b) as i have no clue how to approach this problem. can someone help?
NH3 is a strong base while H2SO4 is strong acid. Since water has a leveling effect, almost 100% of a strong acid yields H3O and almost 100% of a strong base yields OH. This means that when you mix a strong base and a strong acid in equal quantities, the concentration of OH and H3O is almost the same. From Le Chatelier principle, some of the OH and H3O will react to produce H2O (inverse of autoionization). This said, the final concentration of OH and H3O is very close to 10^-7. So you need the same concentration (once mixed in) of each in order to get a Ph of 7.
It is not. I am afraid that's not the only reason that makes your discussion invalid, but the most obvious one.
15K
17K
27K
10K
10K
