Thread Closed
free body diagram?
Share Thread Thread Tools
Apr10-07, 06:55 PM   #1
free body diagram?
Two boxes of masses m=35kg and m2=45kg, are hung vertically from opposite ends of a rope passing over a rigid horizontal metal rod. They system starts moving from rest. Assuming that friction between the rod and the rope is negligible, determine the magnitude of
(a) the acceleration of the boxes
(b) the tension in the rope
(c) the magnitude of each box's displacement after 0.5s
2. Relevant equations
Fnet=ma
Fnet= FT - Fg
ma=FT-Fg
(well i think this is right, depending on how the free body diagram is drawn..)
3. The attempt at a solution
Well...I have no idea what the question is saying, im unsure how to draw the actual diagram and also how to draw the FBD. This is how i inteperted it:
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr10-07, 07:05 PM   #2
maybe im reading it wrong, but the way i read it was that there are 2 boxes tied to each other with a rope and that rope is hung on an iron bar.
Apr10-07, 07:09 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
What's F_R in your diagram?? I agree with fizz on the interpretation of the problem.
Apr10-07, 07:10 PM   #4
Mentor
free body diagram?
I assume you are to treat this just as you would if the rod were a frictionless (and massless) pulley. Draw a free body diagram for each mass separately.
Apply Newton's 2nd law to each mass (just like in your equations) to get two equations, which you'll solve together. Hint: Adopt a consistent sign convention, for example: up is positive and down is negative. Let "a" be the magnitude of the acceleration; how do the accelerations of the masses relate to each other?
Thread Closed
Thread Tools
Similar Threads for: free body diagram?
Thread Forum Replies
Free body diagram Classical Physics 8
Free Body Diagram? Introductory Physics Homework 3
Free-body diagram Introductory Physics Homework 1
Free-Body Diagram Introductory Physics Homework 2
