Scale Factor Ratio: Z Value at End of Inflationary Era
The discussion revolves around the ratio of the scale factor at the present time to that at the end of the inflationary era, specifically seeking to determine the corresponding redshift value. Participants explore various estimates and implications related to the duration and effects of inflation in cosmology.
  • Some participants question whether there is a unique prevailing estimate for the scale factor ratio and express a desire for specific numerical values.
  • One participant suggests that the redshift at the end of inflation could be around 10^25, referencing a visual representation from a Wikipedia article.
  • Another participant mentions that the cosmological neutrino background (CNB) was released at a redshift much larger than 1100, speculating on its estimate being around 10^10 based on a source.
  • There is a discussion about the minimum duration of inflation, with a claim that it must last for at least "100 doublings," which could imply a scale factor ratio exceeding 10^30.
  • Some participants express a desire for not only numerical values but also an understanding of the observational basis for those values, indicating a need for clarity on how these estimates are derived.
  • One participant clarifies that their original question specifically asked for the ratio of the present scale factor to that at the end of inflation, rather than the growth during inflation.
  • There is mention of the Friedmann equations and their potential use in understanding the early history of the universe, contingent on having strong experimental evidence for inflation's timing.
Participants express varying views on the estimates for the scale factor ratio and the implications of inflation, with no consensus reached on specific values or the observational basis for those values. The discussion remains unresolved regarding the exact redshift at the end of inflation and the implications of inflation's duration.
Participants note limitations in the current understanding of inflation's timing and its observational evidence, which affects the ability to set upper bounds on the duration of inflation and the scale factor ratios.
George Jones
Staff Emeritus
What is the ratio of the scale factor now to the scale factor at the end of the inflationary era?
Edit: In other words, what is the z value of the end of the inflationary era?
Space news on Phys.org
I've wondered about that, and whether there even is a unique prevailing estimate (with the amount of slack in the scenarios). I hope you get an answer.
I'll be happy :smile: if someone gives [itex]a[/itex] and [itex]b[/itex] values for [itex]10^x[/itex] with [itex]a < x < b[/itex].
there's a related question, GJ, which you may know the answer to.
(I think it has a definite answer and I may even have read an estimate, but if so it has faded from my memory)
there must be a moment when the CNB (cosm. neutrino background) was released and I wonder what the redshift of that is.
it would be a number much larger than 1100 by many orders magnitude,
but nevertheless somewhat analogous to 1100 as the z for the CMB.
I wonder if anybody here knows an estimate of that z.
Cosmological Physics by Peacock say roughly 10^10.
Red shift for the end of Inflation ~ 1025.
http://en.wikipedia.org/wiki/Image:Inflationary_horizon_plot.svg .
Garth
If inflation is to solve the flatness-oldness problems, inflation must have lasted for a minimum of "100 doublings",
http://www.astro.ucla.edu/~wright/cosmo_04.htm
That would be 10^30 or so.
I think there may be some constraints resulting from the COBE data, but I don't know what they are.
Not quite what I asked :smile: , but the answer seems reasonable according to Figure 2. from http://arxiv.org/PS_cache/astro-ph/pdf/0305/0305179v1.pdf" on inflation. This figure shows the size of the universe (compared to now) when the Standard Hot Big Bang takes over after inflation. This is what I wanted.
This is the paper that marcus referenced in his https://www.physicsforums.com/showthread.php?t=167319".
Thanks marcus, Garth, and pervect!
In a few days, I'll probably ask another question in this thread (my motivation for the first question), but, this time, I want to try and find the answer first!
Well, my reaction to your question and the answers was that I would and did want not only a number, but some idea of what observations gave rise to that number, some understanding of where the number came from.
Assuming that inflation is the reason we don't have a flatness-oldness problem gives at least a lower bound on how long inflation lasted. But what gives an upper bound?
I would expect that the duration (number of doublings) of inflation would have impact on the large scale structure formation, and on the observed slight variances in the CMB. But I'm not sure what assumptions are needed to work backwards from these sorts of observations to put some upper bound on how long (how many doublings) inflation lasted, or what papers might attempt this.
pervect said:
I would expect that the duration (number of doublings) of inflation ... to put some upper bound on how long (how many doublings) inflation lasted, or what papers might attempt this.
Again, this is not what I asked for in my original post.
Let [itex]a_{start}[/itex] be the scale factor at the the beginning of the inflationary era, [itex]a_{end}[/itex] be the scale factor at the the end of the inflationary era, and [itex]a_{now}[/itex] be the scale factor at the present instant.
I asked for the value of [itex]a_{now}/a_{end},[/itex] not for the value of [itex]a_{end}/a_{start},[/itex] i.e., not for the growth during inflation.
Edit: both [itex]a_{now}/a_{end}[/itex] and [itex]a_{end}/a_{start}[/itex] can read off (for two infationary models) of Lineweaver's Figure 2.
Well, the lower bound is still a lower bound :-) - i.e. if you need 100 doublings, during inflation, and then it expands more, you have more than 10^30.
But it makes it even harder to set an upper bound.
I'm not sure if we have a very strong experimental evidence for exactly when inflation occurred (temperature, density, etc). The good news is that if we can come up with such data, we can use the Friedmann equations (assuming we believe them) to give us the early history of the universe. Of course, we need to add in the radiation terms to get the early history.
  • · Replies 93 ·
  • · Replies 17 ·
  • · Replies 18 ·
