Unravelling Spherical Waves: Intensity Behaviour Explained
The discussion revolves around the behavior of spherical waves and their intensity characteristics. Participants explore the mathematical representations of spherical waves, specifically comparing expressions involving complex exponentials and cosine functions, and how these relate to intensity calculations.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants examine the differences in intensity derived from two mathematical forms of spherical waves. Questions arise regarding the implications of time dependence and averaging in the context of intensity calculations.
The conversation is active, with participants providing insights into the nature of spherical waves and the mathematical relationships between their representations. There is an ongoing exploration of how time averaging affects intensity, with some participants noting the oscillatory nature of certain expressions.
Participants are discussing the implications of different mathematical forms under the constraints of wave behavior and intensity definitions. There is an acknowledgment of the need for time dependence in certain wave functions to fully understand their characteristics.
Repetit
Hey!
Im quite confused about spherical waves. I mean, I understand that a spherical wave can be described by
[tex] \Psi = \frac{1}{r} e^{i r},[/tex]
because the intensity of such a wave decreases as [tex]1/r^2[/tex]. The intensity of such a wave is given by [tex]I = 1/r^2[/tex] which makes sense to me. But a spherical wave can also be described by
[tex] \Psi = \frac{1}{r} \cos r,[/tex]
which gives a much different behaviour of the intensity because the intensity of such a wave is [tex]1/r^2 cos^2(r)[/tex]. If these two expressions both describe a spherical wave, how come they don't have the same intensity?
At a guess, I'd say that they're the same thing if you take time averages.
<cos^2(kx-wt)>=1/2
Those are spherical functions as in that they are angle independent. As they have no time dependence, in what sense are they waves?
Okay, so if they both had time dependence [tex]-i \omega t[/tex] so that
[tex] \Psi = \frac{1}{r} e^{i ( k r - \omega t)}[/tex]
and
[tex] \Psi = \frac{1}{r} \cos( k r - \omega t)},[/tex]
but they still don't have the same intensity, since the intensity of the second one is an oscillating function of r and t whereas the first one takes off as 1/r^2 and is therefore not oscillating.
Again, <cos^2(kr-wt)>=1/2 at any particular value of r and averaging over time.
and
? Not oscillating? The second equation is the real part of the first.
But isn't the intensity given by [tex]\Psi \Psi^*[/tex]? This gives an intensity equal to 1/r^2 for the wave described by a complex exponential function but an intensity equal to [tex]1/r^2 cos^2(k r - w t)[/tex] for the other one.
Ah, that's what you're trying to say. Yes, the cos one has a time-dependent 'intensity' and the other doesn't. But as christianjb pointed out, <cos^2>=1/2. So in an average sense one is 1/2 of the other. Not surprising since it's also the 'real half'.
  • · Replies 25 ·
