| Thread Closed |
copper wire in magnetic field |
Share Thread | Thread Tools |
| May8-07, 08:21 AM | #1 |
copper wire in magnetic field![]() A piece of stiff copper wire hangs from a metal between the jaws of a u-shaped magnet and its free end dips into a pool of mercury. Mercury is connected to a positive terminal. piece of stiff wire will move: A towards the south pole B towards the north pole C to the right towards the support D to the left towards the power supply If someone can just tell me what the mercury does i should be right. I'm assuming it would go to either the north or south pole. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May8-07, 08:56 AM | #2 |
Mercury just acts as a liquid conductor which allows the copper wire to move.
| May8-07, 11:49 AM | #3 |
B lines are going from N to S of the magnet, that means they are perpendicular to the flow of electrons. So, yea you need to use the right hand rule. Find the direction in which the wire would move
| Jun7-07, 05:14 PM | #4 |
Well, you know that your current is either flowing up or down (depending on how you've set up the battery). The mercury, as 'Four' stated, is a conductor and will allow for the completion of the circuit. Knowing that the B-Field (magnetic field) is travelling from North to South, use that nifty right hand rule to find the force acting on the current carrying wire. This rule corresponds with the equation F=b.I.l, where force is the direction of your palm, the B-Field is the direction of your fingers and I, current, is the way in which your thumb is pointing.
| Jun9-07, 01:19 PM | #5 |
according to your diagram, the current does not flow either up or down, it flows in olnly one of those directions (look at where the + and - are)
then use the right hand rule |
| Thread Closed |
| Thread Tools | |
Similar Threads for: copper wire in magnetic field
| Copper wire magnetic force help | Introductory Physics Homework | 1 | ||
| copper wire magnetic field | Introductory Physics Homework | 3 | ||
| Magnetic Field, copper wire, and solenoid problem. | Introductory Physics Homework | 2 | ||
