Particle in Magnetic Field: Conceptual
The discussion revolves around a charged particle moving through a uniform magnetic field, analyzing its trajectory and speed as it enters and exits the field. Participants explore the implications of changing the particle's velocity on its path and the time taken to traverse that path.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between velocity and the radius of the particle's circular path, questioning how halving the velocity affects the trajectory and the time taken to complete the path. There is exploration of whether the particle still follows a semicircular path and how this relates to the time of travel.
Some participants have provided hints and guidance regarding the relationship between distance, velocity, and time, suggesting that the time taken remains consistent despite changes in velocity. Others are still grappling with the algebraic implications of their reasoning.
Participants are working under the constraints of a homework assignment that requires them to evaluate multiple statements about the particle's motion without providing definitive answers or solutions.
mbrmbrg
In Figure 28-28 (see attached), a charged particle enters a uniform magnetic field B with speed v0, moves through a half-circle in time T0, and then leaves the field.
Which statements are true? (Select all that apply.)
  1. The charge is positive.
  2. The charge is negative.
  3. The final speed of the particle is greater than v0.
  4. The final speed of the particle is less than v0.
  5. The final speed of the particle is equal to v0.
  6. For an initial speed 0.5v0, T > T0.
  7. For an initial speed 0.5v0, T < T0.
  8. For an initial speed 0.5v0, T = T0.
  9. For an initial speed 0.5v0, the path is more than a half-circle.
  10. For an initial speed 0.5v0, the path is less than a half-circle.
  11. For an initial speed 0.5v0, the path is also a half-circle.
[tex]F_B=qv\times B[/tex]
[tex]F_c=\frac{mv^2}{r}[/tex]
I'm fine until I'm asked to halve the velocity. I combined my two equations and found that when v'=0.5v, r'=0.5r. but I'm not sure how that affects the shape of the trajectory. Will the particle still make a semicircle, only now with a smaller radius? If so, it would make sense that the t'>t. But on the other hand, a smaller velocity should result in a longer time!
I guessed 2, 5, 7, & 11, then I tried 2, 5, 6, & 11. Both combinations are incorrect.
I'd appreciate any help in understanding how velocity affects the trajectory and time. Thanks!
Good. More generally, v/r is a constant.
Yes. Since the magnetic force is always perpendicular to the velocity, it must take a circular path. By symmetry, the path will be a semicircle, only smaller.
What's your reasoning here? Figure it out! Hint: What distance does it travel? How long does it take?
Cool! The particle either travels 2*pi*r with velocity v or 2*pi*0.5r with velocity 0.5v. So time is the same even though velocity changes.
Thanks, Doc!
You've got the idea. (Although a semicircle is only pi*r. :wink: )
:redface: That's me. It seems like when I get the physics, I lose the algebra; when I get the algebra, I lose the arithmetic.
Thanks!
  • · Replies 31 ·
  • · Replies 18 ·
