How to use the residue theorem when I have an exponential as the pole?
The problem involves using the residue theorem to evaluate the integral \(\int^{\infty}_{0} \frac{dx}{x^3+1}\) with a specified contour. The integral is related to a pole located at \(x=e^{\frac{i\pi}{3}}\) within the contour defined for \(R > 1\).
  • Participants discuss the identification of the pole and the calculation of the residue, with some expressing uncertainty about handling the exponential in the residue calculation. Others suggest substituting into the integral along the contour and relate it to the integral along the x-axis.
The discussion is ongoing, with participants exploring different approaches to calculating the residue and the implications of the contour chosen. Some guidance has been offered regarding the nature of the residue and the contour integration process, but no consensus has been reached.
There are mentions of issues with LaTeX formatting, which may affect the clarity of mathematical expressions shared in the discussion.
laura_a
Q. Use residues and the contour shown (where R > 1) to establish the integration formula
[tex]\int^{\infty}_{0} \frac{dx}{x^3+1} = \frac{2\pi}{3 \sqrt{3}}[/tex]
The given contour is a segment of an arc which goes from R (on the x-axis) to Rexp(i*2*pi/3)
For the function [itex]f(x) = \frac{dx}{x^3+1} [/tex]<br /> I have worked out that there is only only one pole inside the contour (R >1) which is [tex]x=e^{\frac{i\pi}{3}}[/tex]<br /> <br /> So the residue would be<br /> <br /> 2 * pi * i * Res_([tex]x=e^{\frac{i\pi}{3}}[/tex]) f(x)<br /> <br /> But I'm not sure how to do that residue as I've never calculated one with an e in it before... any suggestions? :) Thanks<br /> <h2>Homework Statement </h2><br /> <br /> <br /> <br /> p.s sorry I couldn't get the LaTex to show up, someone told me how to do it, but that is obviously not it...[/itex]
The opening tags shouldn't have a slashes.
To deal with the part of the contour along the complex line substitute t*exp(i*2*pi/3) into the integral. You should be able to convince yourself that this part of the contour has been cleverly picked to have a simple relation to the integral along the x axis. If we call the integral along the x-axis I, then the integral along this line going outward is I*exp(i*2*pi/3). Now convince yourself you can ignore the contribution from the arc in the limit as R->infinity. So the total integral along the contour is I-I*exp(i*2*pi/3). (The minus sign coming because we are integrating counterclockwise around the region). Now equate this to what you get from the residue theorem (it's a simple pole, just like in the 1/(x^2+1) case) and solve for I.
Er, it's just a number, like any other. What's giving you problems?
Incidentally, you have the wrong tags for LaTeX. You want
[[/size]tex]YourLatexHere[/tex]
The e doesn't make any difference. It's still lim(z->z0) (z-z0)*f(z). Factor the cubic as (z-z0)*(z-z1)*(z-z2) where the zi's are the three cube roots of -1.
