Calculating Fatigue Breaking Point of Steel Hollow Shaft
  • Thread starter Thread starter boohillie
    Fatigue Shaft
The discussion focuses on calculating the fatigue breaking point of a circular hollow steel shaft, particularly at 1000 and 1,000,000 cycles. Participants explore the necessary material properties, formulas, and software outputs related to fatigue analysis, with considerations for bending and torsion effects.
  • One participant seeks information on the properties needed to calculate the breaking point of a steel hollow shaft under cyclic loading, expressing uncertainty about the formulas or data sources required.
  • Another participant suggests estimating dimensions based on the shaft's yield point and mentions a previous computation related to a hollow rotating cylinder, implying a connection to the current problem.
  • A suggestion is made to start with an S-N curve for the material, questioning whether the fatigue is due to bending or torsion.
  • A participant describes their software that calculates breaking points based on input dimensions and parameters, sharing specific outputs for both hardened and unhardened steel, indicating reliance on diameter variables.
  • One participant discusses the polar moment of inertia and the modulus of rigidity as necessary quantities for analyzing shear in the shaft, noting the importance of material constants and strain gauge theory.
  • A humorous remark is made regarding fatigue, which does not contribute to the technical discussion.
Participants present multiple viewpoints on the necessary calculations and properties for determining the breaking point of the shaft. There is no consensus on a single approach or formula, and the discussion remains unresolved regarding the best method to calculate fatigue breaking points.
Participants mention various assumptions, such as the neglect of bending moments and the reliance on strain gauge theory, which may affect the calculations. The discussion also highlights the dependence on specific material properties and loading conditions, which are not fully defined.
boohillie
I have some calculations I would like to make, though I am having trouble finding information. I have a circular hollow shaft made of steel. I would like to calculate the breaking point of said shaft at 1000 cycles and 1000000 cycles. What kind of information/properties of the metal needs to be known. Is there a formula for this kind of calculation, or is this something that may come from a table of data after performing fatigue tests. I am kind of new to this, sorry if my questions are a little vague.
So, you want to estimate the dimensions of a steel shaft rotating at 1000 cycles which is nearing the yield point? How about: which has reached a bifurcation from stable to marginally stable static equilbrium (wrt centrifugal force)? That is, would predictions from linear elastostatics satisfy you? Oddly enough, I just did the computation for a hollow rigidly rotating cylinder over in the Relativity forum. I obtained the textbook result, so its probably trustworthy!
Start with an S-N curve for the material you are considering. Depending on your expected loading conditions, you may be able to find a curve with comperable alternating stress levels.
Is the fatigue in bending or torsion?
Well here's what I'm trying to accomplish. I have a piece of software that calculates some information for a strain gaged torque shaft. The software takes the Outer Diameter, and Inner Diameter, and some other parameters strain gage specific. It then calculates various numbers. At the end it estimates the breaking points at 1000 cycles, and 1000000 cycles for hardned an unhardened steel. I'm trying to figure out how it works, so I can write a newer version of the software. I have found that the numbers it comes up with rely on only the Diameter variables.
Here is some of the software's output:
Input:
WHAT IS THE SHAFT OD IN INCHES ? 3.755
WHAT IS THE SHAFT ID IN INCHES ? 0.0
WHAT IS THE GAGE FACTOR ? 2.065
WHAT IS THE GAGE RESISTANCE ? 350
WHAT IS THE TOTAL BRIDGE RESISTANCE INCLUDING LEADS ? 350
WHAT TORQUE WILL THE SHAFT SEE IN NM ? 34000
ZERO OUTPUT IN uE ? –225
Output:
CALIBRATIONS
25K = 45634.85 NM
50K = 22817.43 NM
100K = 11408.71 NM
200K = 5704.356 NM
400K = 2852.178 NM
TOTAL BRIDGE OUTPUT AT 34000 NM = 5197.133 MICRO STRAIN
ACTUAL STRAIN IN SHAFT AT 34000 NM = 1258.386 MICRO STRAIN
DATA FOR TYPICAL 1E509 STEEL TORQUE SHAFT IN FULL REVERSAL CYCLES
FOR UNHARDENED STEEL
BREAKING POINT AT 1000 CYCLES = 72172.97 NM
BREAKING POINT AT 1,000,000 CYCLES = 21780.29 NM
CONSERVATIVE RUNNING TORQUE IS .5 TIMES BREAKING POINT
FOR HARDENED STEEL
BREAKING POINT AT 1000 CYCLES = 168682.4 NM
BREAKING POINT AT 1,000,000 CYCLES = 42311.95 NM
Assuming that the bending moment is negligible, the dimensional quantities required for a shaft in shear will be the polar moment of inertia, J. For a hollow shaft:
[tex]J = \frac{\pi (D^4-d^4)}{32}[/tex]
The material quantity required will be the modulus of rigidity, G. The modulus of rigidity is the torsional analog to the normal stress elastic modulus.
[tex]G = \frac{\tau}{\gamma} = const.[/tex]
Now looking at your added program output, there is, as you mentioned, a good amount of strain gauge specific input (you'll need to read up on strain gauge theory). The rest is material constants input which is probably in a lookup table database that the program uses. It also looks like the alternating stresses are around a zero offset.
If your hollow shaft is fatigued, try viagra.
  • · Replies 24 ·
