Solving Equation of Spheroid for Prolate & Oblate
  • Thread starter Thread starter Amith2006
The discussion revolves around the equations of prolate and oblate spheroids, which are derived from the rotation of ellipses around their axes. The original poster expresses confusion regarding the similarity of the equations for both types of spheroids and questions whether the equations should be distinguishable based on their definitions.
  • Participants explore the definitions and equations of prolate and oblate spheroids, questioning the necessity of distinguishable equations. The original poster suggests alternative orientations for the axes to differentiate the equations.
Some participants provide insights into the shapes associated with different spheroid configurations and discuss the implications of rotational symmetry in ellipsoids. There is an ongoing exploration of the relationship between the parameters a, b, and c in the context of the shapes described.
The original poster is navigating homework constraints and definitions related to spheroids, and there are references to specific geometric shapes (cigar and cow-pie) that may require further clarification.
Amith2006
I have a doubt on spheroid equations. A prolate spheroid is obtained by rotating the ellipse,
X^2/a^2 + Y^2/b^2 = 1 {Here a is major axis}
about the semi-major axis a(i.e. X axis). Its equation is,
X^2/a^2 + [Y^2+Z^2]/b^2 = 1
An oblate spheroid is obtained by rotating the ellipse,
X^2/a^2 + Y^2/b^2 = 1 {Here b is major axis}
about the semi-minor axis a(i.e. X axis).Its equation is,
The problem is that both equations are identical. What I have done is that I have taken ‘a’ always along X axis and ‘b’ always along Y axis. Is it necessary that the equations be distinguishable?
In order distinguish between the two, I will have to take ‘a’ along Y axis for one of them. Suppose I take ‘a’ along the Y axis for oblate spheroid case, the equation of the oblate spheroid is got by rotating the ellipse,
X^2/b^2 + Y^2/a^2 = 1
about the semi-minor axis ‘b’(i.e. X axis).Its equation is,
X^2/b^2 + [Y^2+Z^2]/a^2 = 1
Another way is to rotate the ellipse,
first along X axis(i.e. ‘a’) for prolate spheroid in which case the equation becomes,
And then along Y axis(i.e. ‘b’) for oblate spheroid in which case the equation becomes,
[X^2+Z^2]/a^2 + Y^2/b^2 = 1 {Here b is major axis}
Is there a better way to this? Please help.
Start with the general ellipsoid:
[tex]\left(\frac{x}{a}\right)^2+\left(\frac{y}{b}\right)^2+\left(\frac{z}{c}\right)^2 = 1[/tex]
if it is rotationally symmetric around anyone principle axis the the (a,b,c) coefficients for the other two must be equal. Example: if you have rotational symmetry about x then b=c. Further in this example if a is much bigger than b=c then the ellipsoid is cigar shaped. If a is much smaller than b=c then it is "cow-pie" shaped.
Regards,
J. Baugh
Could you please say what are the shapes of Cigar and Cow-pie in this context?
Sure, take a highly eccentric ellipse. Rotate about the long axis and you have an ellipsoid that is long and cylindrical like a tapered cigar.
Take the same ellipse and rotate about the short axis and you have a tapered disk shaped ellipsoid, like the shape of a discus used in track-n-field events or like the pile of defecant a cow leaves behind.
Regards,
James Baugh
So, the equation of prolate spheroid is,
for a>b=c
and the equation of oblate spheroid is also,
but here a<b=c. I that what u meant?
