| Thread Closed |
Energy released in fission |
Share Thread |
| May28-07, 07:38 AM | #1 |
Consider the following problem: 1) Calculate the energy released in the fission reaction, Uranium(235,92) + neutron--->[Uranium(235,92)]*--->Neodymium(143,60) + Zirconium(90,40)+ 3 neutrons + 8 electrons +8 antineutrino 2. Relevant equations 3. The attempt at a solution Solution: If atomic rest masses are used in calculating the Q value, the term 8 e- may be dropped.Let M(U),M(Nd),M(Zr) and M(n) be the atomic masses of Uranium, Neodymium,Zirconium and neutron respectively. Hence, Q=[M(U) - M(Nd) - M(Zr) - {3-1}M(n)]c^2 Q= 197.6 MeV This is the solution given in Schaums book on Modern Physics. Just because atomic rest masses are used, how can we neglect the 8 e- term? |
| May28-07, 07:48 AM | #2 |
Admin
In the fission process, the electrons are not annihilated, so the rest mass of electrons (92) never changes.
Fission does not produce protons - it simply transforms one nucleus into two nuclei. In the fission process, the sum of Z's of the new nuclei (Z1 and Z2) must equal Z(U) = 92, so: If Z1 = 40 (as in Zr), the other nuclei must have Z2 = 52 (Te). If Z2 = 60 (as in Nd), then the other nuclei must have Z1 = 32 (Ge). The number of electrons = Z (which for U = 92). What does change is the atomic binding energy of the electrons, but that is on the order of eV for valence electrons and increases toward the keV range for inner electrons of more massive nuclei. See - http://xray.uu.se/hypertext/XREmission.html |
| May29-07, 11:35 AM | #3 |
| May29-07, 11:40 AM | #4 |
| May31-07, 04:21 PM | #5 |
| Jun1-07, 11:07 AM | #6 |
Recognitions:
If you look at charge balance and assume the initial U was neutral, then you will see that the final Nd and Zi can't be neutral. They must be ionized with a net charge of +8. Hence if you use the neutral atomic masses for them, it already accounts for the 8 extra electrons.
| Jun1-07, 12:20 PM | #7 |
Thats cool!Thanx guys.
| Thread Closed |
Similar Threads for: Energy released in fission
| why there is more energy released in fusion than fission? | High Energy, Nuclear, Particle Physics | 14 | ||
| Energy Released in Fission Reaction | Introductory Physics Homework | 2 | ||
| Energy released in nuclear fission | Introductory Physics Homework | 3 | ||
| In each Fission event 3 neutrons are released. | High Energy, Nuclear, Particle Physics | 3 | ||
| Energy released in fission reaction | High Energy, Nuclear, Particle Physics | 7 | ||
