How do I find out the capacitor?
  • Thread starter Thread starter cseet
    Capacitor
The discussion revolves around a problem involving a series circuit with a resistor and an unknown capacitor connected to a voltage source. The original poster seeks assistance in determining the value of the capacitor based on the voltage across the resistor after a specific time interval.
  • Participants explore the relationship between voltage, resistance, and capacitance using the charging formula for capacitors. There are attempts to manipulate the formula to isolate the capacitance. Some participants question the accuracy of the steps taken in the calculations and the interpretation of the equations.
Several participants have provided insights and corrections regarding the mathematical approach to the problem. There is an ongoing exploration of different interpretations of the equations involved, with no explicit consensus reached on the final value of the capacitance.
Some participants express uncertainty about the mathematical notation used, such as the natural logarithm and exponential functions, indicating a potential gap in understanding these concepts within the context of the problem.
cseet
Hi all
I've a question to the following and would be greatly appreciated if anyone could lend a hand...
Question:
A series combination of a 12 kilo ohm and an unknown capacitor is connected to a 12 V battery. One second after the circuit is completed the voltage across the resistor is 2 V. How do I find out the capacitor?
pls help me to understand and problem...
thanks
cseet
V on capacitor = 12V - 2V = 10V
now,charging formula for a capacitor is: Vs=Vi(1-[e to the power of t/RC])
where Vs is the supply voltage
Vi is the voltage on capacitor
t is the time
R is the resistor
and C is the capacitance
therefor your formula will becoma 12=10(1- [e to the power of 1/12k * C)
all you have to do is just subject of the formula
Also remember that the value of capacitance for a parallel plate capacitor is:
C= Ae/t where e is the dielectric constant, A is the area of the plates and t is the distance between the plates. Usually values of e are given relative, so multiply them by 8.854E-12 farad/meter to get actual material dielectric (permitivity) constant.
tigrot made a little mistake, the power of e is negative:
[tex]V_{(t)} = V_f(1 - e^{-\frac{t}{RC}})[/tex]
[tex]1 - \frac{V_{(t)}}{V_f} = e^{-\frac{t}{RC}}[/tex]
And then just use ln()...
Thank you for correcting me Chen.You are correct.
re
Hi there,
thanks for all your replies. they're really helpful and takes the pain away from learning Physics!
thanks again!
Cseet
yeah ppl are so helpful here
Hi,
I came to an answer of 15C.
the following is how I worked out... correct me if I'm wrong... thanks
12 = 10 (1-exo(-1/12C))
12 = 10 * 0.08 * C
C = 12 / (10 * 0.08)
C = 15 C
am I correct?
thanks
cseet
Hi,
12 = 10 * 0.08 * C
C = 15 C
am I correct?
thanks
cseet
hi guys,
pls ignore my above equation... I got it all wrong... fond out the answer... thanks anyway...
cseet
I don't understand how you got from here:
[tex]12 = 10(1 - e^{-\frac{1}{12C}})[/tex]
To here:
[tex]12 = 10 (0.08C)[/tex]
I don't think you read the equations above right. The capacity C is part of the power of e, you cannot leave it out and only raise e to the power of 1/12. Do as I said - from this:
Take the ln() of both sides to get:
[tex]ln(1 - \frac{V_{(t)}}{V_f}) = -\frac{t}{RC}}[/tex]
[tex]C = -\frac{t}{R ln(1 - \frac{V_{(t)}}{V_f})}}[/tex]
The answer I get is C = 46.5 micro-farads.
sorry this may be a very stupid question... but what does In() mean? and where's exp in this equation.
I do apologise for my ignorance...
cseet
ln is Logarithm Natural, i.e log with the natural base e. If:
[tex]b = a^x[/tex]
Then:
[tex]x = \log _ab = \log _aa^x[/tex]
With ln, the base of the log is simply e. So if:
[tex]b = e^x[/tex]
Then:
[tex]x = \ln b = \ln e^x[/tex]
So when you have this equation:
You are allowed to take the ln of both sides:
[tex]\ln (1 - \frac{V_{(t)}}{V_f}) = \ln e^{-\frac{t}{RC}}[/tex]
The left side stays the same, and the right side just becomes [itex]-\frac{t}{RC}[/itex].
