Is there any difference between Miscible and Soluble?
by jkh4
Tags: difference, miscible, soluble
jkh4
jkh4 is offline
#1
Jun1-07, 02:58 PM
P: 51
Are there any differences between the terms Miscible and Soluble? I am kind of confuse between these two terms. Are they interchangeable? Thank you!
Phys.Org News Partner Chemistry news on Phys.org
Space-tested fluid flow concept advances infectious disease diagnoses
New, more versatile version of Geckskin: Gecko-like adhesives now useful for real world surfaces
Researcher develops novel wastewater treatment fabric
chemisttree
chemisttree is offline
#2
Jun1-07, 03:02 PM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,725
Miscible generally refers to two liquids. Soluble generally refers to a property of a solid in a liquid. Otherwise, spelling is the only difference.
Kushal
Kushal is offline
#3
Jun1-07, 11:08 PM
P: 440
maybe i'm wrong, but, when a substance dissolves, there is an energy change, e.g for NaCl to dissolve in water at rtp, the Delta H is +5kJ/mol
but for miscible substance i'm pretty sure there's no energy change... because the molecules only get between each other....
haiha
haiha is offline
#4
Jun2-07, 07:04 AM
P: 137
According to me, miscible word is used only for 2 or more liquids.
Surely the 2 phenonmena have + entropy.
Khshal says there's no change in energy in miscible substances. I am not very sure. But some liquids give off heat when being mixed.
chemisttree
#5
Jun3-07, 10:31 AM
Sci Advisor
HW Helper
PF Gold
P: 3,725
There is indeed heat of mixing for two or more miscible liquids. For miscible liquids, entropy and enthalpy effects are not usually as high as with solids dissolving into liquids. Haiha is correct... some liquids do give off heat when mixed. Some absorb heat when mixed. Heat absorption by mixing two liquids (one saturated salt (LIBr) the other distilled water) is the basis of natural gas and solar-powered absorptive air conditioning.
JGM_14
JGM_14 is offline
#6
Jun4-07, 11:12 AM
P: 158
some substances dissociate when mixed and create heat and others go through an endothermic reaction like ammonium nitrate and water, some you mix and expect to be more and there is less (mix 1 ml with 1ml and get 1.5ml)like isopropyl alcohol and water, that is miscible
the only diffirence i know between miscible and soluble is the person saing it because my science teacher didn't use the word miscible very often, only when we were taking notes and we had to know what it ment, even when we were doing labs. She would refer to liquids being soluble in a liquid.
ilovechemistry
ilovechemistry is offline
#7
Jun5-07, 05:21 AM
P: 3
chemisttree provided an easy understanding to it. miscible simply means two liquids mixing together while soluble is when a solid added in solution and dissolves. i hope its right..
Nerro
Nerro is offline
#8
Jun5-07, 04:55 PM
P: 47
Miscible is said when two liquids can be mixed with eachother. Water and oil are not miscible but water and ethanol are miscible.
Soluble is what you call a substance when it can dissolve into a solvent.
Both systems entail a change in entropy and as such will cause the exchange of energy with the surroundings.
WARGREYMONKKTL
WARGREYMONKKTL is offline
#9
Jun8-07, 01:03 PM
P: 54
To my best understanding that the words miscible and soluble that our friend mentioned here is talking about the physical properties of the solute and the solvent.
as I know that when we mix substances together they are aither miscible or unmiscible. However, "soluble" refers to dissolving of a solid substance which we call solut into a large amount of solvent which is another substance. There are of course that energy require because of entropy of the system have changed when the solute is dissolve. Howeve, physically, the solubility of a solid is depend on its solubility constant Ksp.
I think that we hav talk so far into the energy concept of a physical problem.
My reply is utmost to my knowledge, but I am sure that comment is necessary. Please feel free to comment so we all can study more about science.
Best regard guys!
jkh4
jkh4 is offline
#10
Jun8-07, 02:30 PM
P: 51
Thank you for the explainations :) That really helps!
Register to reply
Related Discussions
Are hydrocarbons miscible? Chemistry 8
conductivity with soluble salts Biology, Chemistry & Other Homework 3
soluble groups? Linear & Abstract Algebra 9
How many times more soluble........ ASAP HELP Biology, Chemistry & Other Homework 14
Soluble Cations and Anions Biology, Chemistry & Other Homework 1
