Another simple question: Derivation of the formula for temp. conversion
  • Context: High School
  • Thread starter Thread starter sk381
    Derivation Formula
The discussion revolves around the derivation of the formula for converting Celsius to Fahrenheit, specifically the formula Tc = (5/9)*(Tf-32). Participants seek clarification on the reasoning behind this formula and its components.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant requests a simple explanation of how to derive the Celsius to Fahrenheit conversion formula.
  • Another participant suggests that the derivation involves understanding the ratio of temperature increments and the differences in starting points between the two scales.
  • A participant reiterates the formula and provides context about the relationship between Celsius and Fahrenheit degrees, mentioning that 1 Celsius degree is equivalent to 9/5 of a Fahrenheit degree and noting the freezing points of water on both scales.
  • A link to an external resource is provided, which may offer additional insights into the topic.
Participants express varying levels of understanding regarding the derivation, with some agreeing on the basic principles while others seek further clarification. The discussion does not reach a consensus on a clear derivation method.
Some assumptions about the familiarity with temperature scales and the mathematical relationships involved may be missing. The discussion does not resolve the specific steps in the derivation process.
sk381
Can some one point me to or explain in simple terms, the derivation of the formula to convert celsius into fahrenheit?
Thanks!
I'm not sure what you mean by derivation. It is just the ratio of the increments minus the difference between starting points.
re : Derivation of the formula for temp. conversion
I mean, how does one arrive at this:
Tc = (5/9)*(Tf-32)
or what do you mean by "It is just the ratio of the increments minus the difference between starting points."
I know it might be very trivial but I'm just having a hard time getting to it..
Thanks..
Tc = (5/9)*(Tf-32)
Thanks..
1 celsius degree is 9/5 of a fahrenheit degree. on the fahrenheit scale the temperature water freezes at is 32 , on the celsius scale the correspondent temperature is zero. that's it, and that's exactly what russ meant.
  • · Replies 0 ·
