C Book Recommendations for High School Students
The discussion revolves around recommendations for books on the C programming language suitable for high school students. Participants share their experiences and preferences regarding various texts, considering factors like clarity, comprehensiveness, and suitability for beginners versus more experienced programmers.
  • Some participants recommend "C Companion" by Allen Holub as a good resource.
  • Others suggest "C Primer Plus" and "The C Programming Language" (K&R) as valuable texts, with K&R noted as a classic reference.
  • A participant elaborates on K&R, stating it is the standard book on C but may be terse for complete beginners.
  • Some express concerns that K&R may not adequately cover modern ANSI C due to changes in the language over time.
  • There are mixed opinions about the instructional quality of K&R, with some stating it is not written for beginners and may require supplementary materials for programming concepts.
  • One participant mentions a Turbo C book that they found helpful for understanding memory function calls and formatting.
  • Another participant shares a preference for O'Reilly books and recommends "C: A Reference Manual" by Harbison and Steele.
  • Some participants question the necessity of learning C alone, suggesting that C++ might be more relevant for modern programming needs.
  • Concerns are raised about the quality of books by Herb Schildt, with some participants expressing skepticism about his accuracy in describing the C language.
Participants express a variety of opinions on the best resources for learning C, with no clear consensus on which book is definitively the best. While some recommendations are repeated, there are significant disagreements regarding the suitability of K&R for beginners and the relevance of certain texts to modern C programming.
Some participants note that K&R may not cover newer standards of C, and there are differing views on the instructional quality of various recommended texts. The discussion reflects a range of experiences and preferences, highlighting the subjective nature of book recommendations in programming education.
Ki Man
I was wondering if you guys had any recommendations for a good C book (not C++ or C#), they are very heavily outnumbered by C++ books but i wanted to know if you guys knew any that were good in particular for high school level students.
Technology news on Phys.org
I recommend "C Companion" by Allen Holub.
C Primer Plus; and the good old The C Programming Language. :)
Just to elaborate, KTC is talking about https://www.amazon.com/dp/0131103628/?tag=pfamazon01-20. I agree with that choice. It's the standard book on C, as in 'standard against which other books are judged'. It's small. Only thing is it might be a bit terse if you've never done any programming whatsoever. But if you've even hacked out something in BASIC, you should be fine with this book. I love it anyway.
I second the recommendation of C Primer Plus.
I am not recommending any books on C (because I don't know about any, and also because I mainly do C++ rather than C).
Now if you are a beginner:
If you go on the link given below, you can download the DEV compiler, which compiles both C and C++.
The link is: http://www.bloodshed.net/dev/devcpp.html
Out of the three download options, choose the first one ( 9 MB download).
The best thing about this compiler is that it has got its own full-fledged tutorial on C, which takes you from the most basic to the most complex.
Just download the file, install it and run it. Click on File -> New -> Source File.
This will open a notepad-like file inside the compiler on which you can write the code. After writing the code you can just click on Execute -> Compile and Run.
To get started on the tutorial, just go to Help -> Help on Dev C++.
The tutorial will be a good starting point for you, after which you can advance to the books recommended by other members.
This is how I first learned C. After learning C, it is very easy to adapt to C++ (you will find that yourself).
However, if you are not a beginner, and just want to increase your field of knowledge of C, then you don't need to do anything written by me in the above lines.
regards
Mr V
The Kernighan and Ritchie book, "The C Programming Language" (2nd Ed) is the classic book for learning C, and will remain valuable as a reference. (The book is generally referred to as the K&R book.)
The K&R book is probably a bit too intense for first-time programmers, but if you have experience with other languages (especially c-like languages) it's probably a good choice.
In my experience, the Internet is the best place to find information about programming languages.
The other problem with K&R is that C changed a bit when it became an ANSI standard. It really isn't the best book at all to learn "modern" ANSI C.
- Warren
- Warren
There is a second edition. And there is a "stamp" on the cover that says ANSI C.
Ah, in that case, I may be wrong. I've only seen the first edition, and it's rather archaic.
- Warren
The K&R book is not very instructional. It is not written by educators and I agree with chroot, it is archaic.
K&R is a good book to learn C from, but it's not the greatest book to learn how to program from (algorithms, data structures, software design, etc). If all you need is to learn the syntax and structures for C, K&R will do that for you. If you're just starting to learn how to program or need to start from basics, you'll need additional material to learn from.
K&R may be old, but AFAIK the fundamentals of C haven't really changed all that much. I've had the 2nd ed since it came out and still use it as a reference.
It's worse for C++ than C, but not for these two (possibly among others) languages. Most of the information on the web for these are absolutely rubbish.
TCPL is fine for C89 (C90). It obviously doesn't contain anything from C99 which C Primer Plus, but then there isn't many books on C published that contain information on C99.
The problem is not who it was written by, but rather who it was written for. The target audience had been existing programmers, not someone completely new to programming. It's a good book for learning the programming language, not programming. No single book is going to help someone new to suddenly be able to program (with good algorithms, data structures, SE technique etc.).
there's a turbo C book i really liked because it was very descriptive about memory function calls and printf formatting...K&R is standard but i didn't really like it because it didn't have many of the things i was looking for ...or maybe i didn't look through it carefuly enough.
I'll get the book title as soon as i can find the book...
but whatever text you learn from always look for this statement
printf("%p",...); Its very important to learn about displayign the pointer address if you don't know how to use a debugger. And its from the turbo C book that i learned the pointer printing.
https://www.amazon.com/dp/0895885956/?tag=pfamazon01-20
K&R is really the 'definitive guide' of C. I'd keep a copy in your laptop bag at all times if I were you.
The book I started to learn by was "C all in one desk reference for dummies" by Dan Gookin. It's not really that exhaustive, but it's enough to make simple programs and get the C bug!
Hi,
The complete reference is the best book for C.
I learned from "C The Complete Reference" by Herb Schildt. You might also look at "Teach Yourself C" by the same author. And I learned a lot of basic C++ from "C++ Primer Plus", so I can recommend the author Prata (same as C Primer Plus).
Unless he has improved a lot Herb Schildt is a disaster.
His previous books described a language similair to, but definitely not 'C'.
If you have some background in programming the O Reilly Practical C Programming is good. If you like a more example filled slower pace the Wrox Beginning C Programming.
But if you know programming or other languages you can't beat K+R.
Another question is why you would learn just 'C'? Unless you are doing very tiny microcontroller stuff you should start with C++.
*nod*
C Primer Plus is I heard on the good side, C++ Primer Plus so so.
I've always like O'Reilly books, I generally check to see what they have to offer before I check out anything else
For a C reference manual I like 'C: A Reference Manual' by Samual Harbison and Guy Steele
  • · Replies 17 ·
  • · Replies 16 ·
11K
  • · Replies 23 ·
