Solve Two Identical Waves Superposition Problem
The problem involves two identical sinusoidal waves with a wavelength of 6.00 m and a speed of 2.00 m/s. To ensure the resultant wave maintains the same amplitude as the individual waves, the minimum time interval between their starting moments must be 2.00 seconds. This is derived from the requirement that the phase difference between the waves must be either 0 or π, leading to the conclusion that the second wave should start 2.00 seconds after the first wave.
  • Understanding of wave properties, specifically sinusoidal waves
  • Familiarity with the concept of superposition in wave mechanics
  • Knowledge of trigonometric identities and equations
  • Ability to manipulate phase relationships in wave equations
  • Study the principles of wave superposition and interference patterns
  • Learn about phase difference and its impact on wave amplitude
  • Explore trigonometric identities relevant to wave equations
  • Investigate real-world applications of wave interference in physics
Students studying physics, particularly those focusing on wave mechanics, as well as educators seeking to explain wave superposition and amplitude relationships.
maxpowers_00
hi, i was able to get all of my homework problems except this one, i just ccan not seem to figure it out.
Two identical sinusoidal waves with wavelengths of 6.00 m travel in the same direction at a speed of 2.00 m/s. The second wave originates from the same point as the first, but at a later time. Determine the minimum possible time interval between the starting moments of the two waves if the amplitude of the resultant wave is the same as that of each of the two initial waves.
any help with this problem would be great.
thanks
If the sum of the waves is to have the same amplitude as each individual wave, then its coefficient must be 1. That means that it is a shifted sine wave. For convenience, let the first wave be positioned such that it's mathematical representation is sin(x). Then the second wave is simply shifted in phase.
We essentially have two variables running around. We have the phase of the second original wave and we have the phase of the resultant wave. Let a = the phase of the second original wave and let r be the phase of the resultant wave.
Let us make an expression for the sum of the two original waves.
sin(x) + sin(x + a)
using some trig formulas
sin(x) + [sin(x)cos(a) + cos(x)sin(a)]
[1 + cos(a)]sin(x) + cos(x)sin(a)
now, in order for this wave to have the same amplitude, it must be able to be represented as a shifted sine wave of coefficient 1, i.e.
sin(x + r)
expand
sin(x)cos(r) + cos(x)sin(r)
We want this to be equal to the sum of the two original waves, so
sin(x)cos(r) + cos(x)sin(r) = [1 + cos(a)]sin(x) + cos(x)sin(a)
this equation is only true if the coefficients on both sides of the equation of sin(x) and cos(x) are equal, so this yields the system of equations
cos(r) = 1 + cos(a)
and
sin(r) = sin(a)
which must be solved in order to get the answer.
cookiemonster
To solve this problem, we first need to understand the concept of superposition. When two waves with the same frequency and wavelength travel in the same direction, their amplitudes add together to create a resultant wave.
In this problem, we have two identical waves with a wavelength of 6.00 m and a speed of 2.00 m/s. This means that the frequency of each wave is 2.00/6.00 = 1/3 Hz.
To find the minimum possible time interval between the starting moments of the two waves, we need to consider the phase difference between them. Since the two waves originate from the same point, we can assume that they are in phase at the starting point. This means that the phase difference between them at any other point will depend on their wavelength and the distance traveled.
Let's consider the point where the second wave starts. The first wave would have traveled a distance of 2.00 m/s x t, where t is the time interval between the starting moments of the two waves. The second wave would have traveled a distance of 6.00 m in the same time interval. This means that the phase difference between the two waves at this point is given by 2π(6.00 m - 2.00 m/s x t)/6.00 m = 2π(1 - t/3).
For the resultant wave to have the same amplitude as the initial waves, the phase difference between them must be either 0 or π. This means that the minimum possible time interval t is when the phase difference is π, which gives us 2π(1 - t/3) = π. Solving for t, we get t = 2.00 s.
Therefore, the minimum possible time interval between the starting moments of the two waves is 2.00 seconds. This means that the second wave must start 2.00 seconds after the first wave in order for the resultant wave to have the same amplitude as the initial waves.
I hope this helps you solve the problem. If you have any further questions, feel free to ask. Good luck with your homework!
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 16 ·
