| Thread Closed |
capillary rise in vaccume |
Share Thread | Thread Tools |
| Jul18-07, 03:38 AM | #1 |
if gravitation is present, will there be a capillary rise of liquid in vaccume?
| Jul18-07, 05:44 AM | #2 |
Your question isn't clear.
If the capillary fluid 'wets' the capillary walls, there will be a slight rise of the fluid due to the surface tension pulling the fluid to adhere to more of the wall surface. When the surface tension attraction force is balanced by the force of weight of the lifted column the level will remain at that point. If you're talking about a manometer type of device, the fluid will behave accordingly to the pressure difference between the ambient pressure inlet port and the fluid reservoir pressure i.e. the pressure on the other end of the fluid column. What would cause the fluid to rise if it were not vacuum? What would cause the fluid to rise in the vacuum? What would be the effect on the fluid if the device were transported from a sea-level atmposphere environment up to higher and higher altitudes until it was in a vacuum? If the device works to measure something in a fashion then that measurement process should apply continuously over some range of measurements, with vacuum (zero ambient pressure) being one ultimate case. Of course some fluids have high vapor pressure in vacuum at normal temperatures, so it's possible that the fluid is not compatible with vacuum at the temperature you'd be operating it... In fact the fluid would have to have a significant surface tension otherwise it'd certainly quickly 'boil' / 'evaporate' at comfortable temperatures in vacuum. |
| Jul18-07, 06:23 PM | #3 |
didn't Einstein write a paper on this?
| Jul19-07, 12:07 AM | #4 |
capillary rise in vaccumewould have been in the topic. It seems like something that would be very straightforwardly explained by classical hydraulics / gas law theories long before Einstein's time. I know that fluid filled manometers were often used for measuring pressures from atmospheric all the way down to moderately high vacuum levels in lab settings, and it wouldn't be uncommon to leave one connected to one's vacuum system even once the pressure had gone down to the point where the manometer wouldn't be able to usefully measure it (p < 1 Torr). Of course you'd need to use good vacuum pump oil or mercury or something vacuum compatible in the tubes. |
| Jul19-07, 03:24 AM | #5 |
I mean if we keep a water container in vaccume and glass capillary tube is dipped in it will there be a rise of water in the capillary tube? If 'yes' is that height of rise same ,if the same expt is done outside the vaccume at the same place?
I am asking this because we explain the rise in capillary by considering the pressure difference at same distance above and below the liquid level in the capillary tube. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: capillary rise in vaccume
| Capillary Action (Capillary Depression) | General Physics | 2 | ||
| capillary action | Advanced Physics Homework | 3 | ||
| Capillary interaction on a fluid surface | Introductory Physics Homework | 0 | ||
| The heart's overcoming capillary viscosity | Biology | 3 | ||
