Exercise superposition difficulties
The discussion revolves around solving a circuit exercise involving superposition, specifically focusing on the configuration of resistors and the calculation of voltage across a 40-ohm resistor. Participants explore the relationships between resistors when short-circuiting a voltage source and open-circuiting a current source, as well as the implications for applying Kirchhoff's laws.
  • One participant expresses confusion about the configuration of resistors when short-circuiting the voltage source, questioning whether the 20-ohm and 40-ohm resistors are in parallel and how other resistors relate to this combination.
  • Another participant confirms that the 20-ohm and 40-ohm resistors are in parallel, sharing nodes with the 10-ohm resistor, which is in series with them.
  • There is a suggestion to redraw the circuit for clarity, which some participants find helpful.
  • One participant questions whether the 2.5-ohm and 10-ohm resistors are in series when the current source is open-circuited, leading to further clarification about their connections.
  • Another participant proposes a method for calculating the voltage across the 40-ohm resistor using a combination of series and parallel resistor configurations and voltage divider principles.
  • There is a correction regarding the calculation of total current, emphasizing the need to consider how current splits between branches in the circuit.
Participants generally agree on some aspects of the resistor configurations, but there remains uncertainty and differing interpretations regarding the exact relationships and calculations involved, particularly in the context of applying Kirchhoff's laws and voltage division.
Some assumptions about the circuit configuration and the application of superposition may not be fully articulated, leading to potential misunderstandings in the calculations proposed by participants.
esmeco
Hello!
I'm having a bit of a difficulty trying to solve this exercise mostly because of the resistors.
So,when short circuiting the voltage source we have the 20ohm in parallel with 40 ohm right?But what about the other resistors are they in parallel or in series with the result 20//40?The exercise tells to determine the voltage with superposition in the 40ohm resistor.
And what about if we open circuit the current source?Are the 2.5 ohms and 10ohm in series with each other?
What kind of process should I adopt to solve for the voltage in 40ohm resistor?Currents in equal currents out?
Any help is really appreciated!
Anyone can help me?
Short ciruciting the voltage source makes the 20Ω and 40Ω share two common nodes, so they are in parallel. That combination share one node with the 10Ω, so they are in series. Then that combination share two commons with the 2.5Ω resistor and the combination of resistances is in series with the current source.
The 2.5Ω and 10Ω have one node in common. Therefore they are . . . ?
Voltage drop, V, across a resistor of resistance R is given by V = i R where i is the current through the resistor.
Try redrawing
One thing that always helps me is redrawing a messy looking circuit to something more conventional. This may help you to visualize what Astronuc was taking about. [Sorry for the sloppiness].
But,doesn't the combination 20//40 also shares a node with 2.5ohm resistor besides the 10ohm?
The redrawn image has been approved. Following Astro's advice can you now make it out?
Yes, the 20//40 share one common node with the 2.5Ω resistor, and they share one common node with the 10Ω resistor, but those two common nodes are different.
The 20//40Ω + 10Ω are parallel with the 2.5Ω resistor.
So,the KCl for the shorted voltage would be something like this:
va/2.5 + (va-vb)/10=6
(va-vb)/10=vb/10 + vb/20
Am I right?
Oh,and could the voltage in the 40 resistor in the open current source be calculated by 10 and 2.5 in series,in parallel with 40 volts,in series with 20 resistor,and then calculate the total current since we have the 100 voltage source.And with the total current calculated multiplied by the 40 ohm resistor in order to determine the tension in the resistor?
You were correct until the last sentence. The total current gets split between the 40 ohm branch and the 10 + 2.5 series branch. The best way to find that voltage is to keep the 40 || (10 + 2.5) combination together and use voltage divider for that combination and the 20 ohm. This works because the voltage across the 10 + 2 combination is the same as the voltage across the 40 since they're in parallel.
Voltage divider, if you don't recall is Vbranch = Vtotal * (Rbranch/Rtotal) and only works on series circuits.
  • · Replies 37 ·
