Phototransistor vs photodiode ?
  • Thread starter Thread starter TechSpec
    Photodiode
The discussion centers on the compatibility of phototransistors and photodiodes in conjunction with Atmel's IR-amplifier IC, which is designed specifically for photodiodes. Users highlight that phototransistors, while offering gain advantages, require different biasing and connection methods due to their three-pin configuration compared to the two-pin setup of photodiodes. The recommended approach for using photodiodes involves reverse biasing and utilizing op-amp circuits for optimal performance, especially for fast IR signals. The conversation also emphasizes the importance of using an IR-bandpass filter to mitigate interference from daylight in high-distance applications.
  • Understanding of Atmel IR-amplifier IC specifications
  • Knowledge of photodiode and phototransistor operation
  • Familiarity with op-amp circuits for signal processing
  • Experience with IR signal modulation and filtering techniques
  • Research the specifications and applications of Atmel's IR-amplifier IC
  • Learn about the differences in biasing between photodiodes and phototransistors
  • Explore the design and implementation of op-amp circuits for photodetector applications
  • Investigate the use of IR-bandpass filters in optical systems for enhanced performance
Electronics engineers, hobbyists working on IR sensor projects, and anyone involved in designing optical detection systems will benefit from this discussion.
TechSpec
HI all,
i'm currently working with IR sensor diodes, and trying to find a proper device for my project, however i haven't found a good unit which fills my needs. Now that i have extended my search to phototransistors, i wonder are they compatible with photodiodes?
Im using Atmel's IR-amplifier IC and the datasheet only suggest of using photodiodes, as the IC have only 2 input pins for diode. But can i also use phototransistors?, they have 3 pins, so how should i connect them to device which only have two input pins for diode?
Im thinking that, if the IR light represents as a base control "current" then i should use collector-emitter to be as a anode-kathode in diode, am i right?
TechSpec
What IR source are you wanting to detect, and at what distance? What is the bandwidth of the modulation of the IR source?
PIN photodiodes are best for fast IR signals. You reverse bias them at several volts, and use an opamp circuit to convert the photocurrent to an output voltage. Phototransitors are slower to respond -- the photocurrent acts as base current into an NPN transistor. So you connect a phototransistor up with a grounded base and an collector resistor to the + supply rail, and use the collector voltage as the output. The advantage of the phototransistor is that you get the gain of the transistor, so you get more output response for the same input IR level, as compared to the PIN photodiode.
Does that help?
Actually, i skipped OP-circuits because some manufacturers offer ready made, highly developed amplifiers in one chip, like for example Atmel, those have built-in interference filter circuits and such as AGC(auto gain control) and ATC (auto strong signal adaptation) to be a complete amp unit, its tuff task to produce such a thing with discretes...
http://www.atmel.com/dyn/resources/prod_documents/doc4905.pdf
I'm thinking that since they have connected the diode internally to their amplifier, connecting a phototransistor would not work at all because of a different biasing etc.
My IR source is a 850nm 50mW LED and the detector is Pi detector at 850nm.
Emitter will emit 0.5ms bursts of 38kHz square at 50% ratio.
System uses optics so the distance will be >30m, and because the photodetector does not have daylight blocker, i will use IR-bandpass filter behind the optics to do the job.
TechSpec
Yeah, from a quick look at the datasheet, it looks like it is made for a PIN photodiode. The biasing for a phototransistor would be different. Sounds like a fun project!
