Efficient Matrix Transformations for C++ Programming
The discussion centers around the implementation of matrix transformations in C++, specifically focusing on algorithms for converting matrices to row echelon form and reduced row echelon form. Participants explore various approaches to matrix inversion and the efficiency of different algorithms, while also considering the implications of matrix size and type.
  • One participant seeks assistance in finding algorithms for transforming matrices to row echelon form and reduced row echelon form, noting the potential use of these algorithms for matrix inversion.
  • Another participant outlines a detailed step-by-step algorithm for achieving reduced row echelon form using a specific 3x3 matrix example.
  • A third participant references a resource, "Numerical Recipes," suggesting it may contain relevant information on the topic.
  • Concerns are raised about the efficiency of the outlined algorithm for large matrices, with a participant noting that while square matrices are manageable, rectangular matrices present additional challenges.
  • Discussion includes the complexity of the Gaussian elimination algorithm, with one participant mentioning its O(n^3) time complexity and the potential for optimization using Strassen's algorithm for specific cases.
  • Another participant questions the necessity of finding the inverse of a matrix, suggesting alternative methods to solve equations without computing the inverse.
  • A participant expresses their intent to practice programming skills through this task and considers implementing the discussed algorithms in C++, while also contemplating the efficiency of recursive methods.
Participants express a variety of viewpoints regarding the efficiency and necessity of different algorithms for matrix transformations and inversions. There is no consensus on the best approach, and multiple competing views remain throughout the discussion.
Participants mention limitations related to the size and type of matrices being handled, as well as the potential inefficiencies of recursive methods for large datasets. The discussion does not resolve these limitations.
DrKareem
I'm making a matrix class that allows the user to manipulate with matrices, on C++ that is.
I'm having difficulties finding the algorithms of transforming a matrix to it's row echelon form or reduced row echelon form. The last one could help in finding the inverse of a matrix.
My teacher advised me not to develop the algorithms and get them online. So I'm wondering if anybody knows anything about those that could help.
Computer science news on Phys.org
Here is the strategy for reduced row echelon form. Follow it carefully
Say you have a 3x3 integer array
[ 2 , 21 , 3 ]
[ 4 , 15 , 18 ]
[ 8 , 3 , 9 ]
Definition: (Row) Pivot = first non-zero digit in the row
Step 1
Pivot = (0,0) = 2
Multiplier = (1, 0) / Pivot = 4/2 = 2
(1,0) = (1, 0) - Multiplier * (0,0)
(1,1) = (1,1) - Multiplier * (0,1)
(1,2) = (1, 2) - Multiplier * (0,2)
Or simply
Row 1 = Row1 - Multiplier * Row 0
[ 2 , 21 , 3 ]
[ 0 , -27 , 12 ]
[ 8 , 3 , 9 ]
Step 2
Pivot = (0,0) = 2
Multiplier = (2, 0) / Pivot = 8/2 = 4
(2,0) = (2, 0) - Multiplier * (0,0)
(2,1) = (2,1) - Multiplier * (0,1)
(2,2) = (2, 2) - Multiplier * (0,2)
Or simply
Row 2 = Row2 - Multiplier * Row 0
[ 2 , 21 , 3 ]
[ 0 , -27 , 12 ]
[ 0 , -81 , -3 ]
Step 3
Pivot = (1,1) = -27
Multiplier = (2, 1) / Pivot = -81/-27 = 3
(2,1) = (2,1) - Multiplier * (1,1)
(2,2) = (2, 2) - Multiplier * (1,2)
Or simply
Row 2 = Row2 - Multiplier * Row 1
[ 2 , 21 , 3 ]
[ 0 , -27 , 12 ]
[ 0 , 0 , -33 ]
Step 4
Pivot = (2,2) = -33
Multiplier = (1, 2) / Pivot = -(12/33)
(1,2) = (1,2) - Multiplier * (2,2)
Or simply
Row 1 = Row1 - Multiplier * Row 2
[ 2 , 21 , 3 ]
[ 0 , -27 , 0 ]
[ 0 , 0 , -33 ]
Step 5
Pivot = (2,2) = -33
Multiplier = (0, 2) / Pivot = 3/-33 = -(1/11)
(0,2) = (0,2) - Multiplier * (2,2)
Or simply
Row 0 = Row0 - Multiplier * Row 2
[ 2 , 21 , 0 ]
[ 0 , -27 , 0 ]
[ 0 , 0 , -33 ]
Step 6
Pivot = (1,1) = -27
Multiplier = (0, 1) / Pivot = 21/-27 = -(7/9)
(0,1) = (0,1) - Multiplier * (1,1)
Or simply
Row 0 = Row0 - Multiplier * Row 1
[ 2 , 0 , 0 ]
[ 0 , -27 , 0 ]
[ 0 , 0 , -33 ]
Step 7
Pivot = (0,0) = 2
Row 0 = Row 0 / Pivot
[ 1 , 0 , 0 ]
[ 0 , -27 , 0 ]
[ 0 , 0 , -33 ]
Step 8
Pivot = (1,1) = -27
Row 1 = Row 1 / Pivot
[ 1 , 0 , 0 ]
[ 0 , 1 , 0 ]
[ 0 , 0 , -33 ]
Step 9
Pivot = (2,2) = -33
Row 2 = Row 2 / Pivot
[ 1 , 0 , 0 ]
[ 0 , 1 , 0 ]
[ 0 , 0 , 1 ]
If your interested in finding the Inverse matrix, just augment the one above with the identiy matrix
[ 2 , 21 , 3 | 1 , 0 , 0 ]
[ 4 , 15 , 18 | 0 , 1 , 0 ]
[ 8 , 3 , 9 | 0 , 0 , 1 ]
Then do the same procedure but when doing the multiplier row operations, make sure to do it to the right side of the augmented matrix as well.
Here is the first step with the the augmented matrix:
[ 0 , -27 ,12 | -2 , 1, 0 ]
Have a look at Numerical Recipes:
http://www.library.cornell.edu/nr/cbookcpdf.html
cf. Chapter 2.
- Warren
dduardo, the algorithm that you used is really nice, but in certain cases, when you have for example huge matrices is perhaps inefficient, since it would require a huge numbre of iterations. It's easy to figure out an algorithm for square matrices, but for rectangular ones it becomes harder.
Chroot, i haven't looked on the lib you gave yet, but i will see it later and comment on it.
Are you looking for a fast matrix inversion algorithm or are you looking for a reduced row echelon algorithm that you can then apply to do matrix inversion? As you probable already know, the method I showed you in my previous post was a basic Gaussian elimination alogrithm that is O(n^3). If you just want to invert matrices you have to ask yourself what type of matrices you intend to invert? Are they dense, sparse, symmetric, banded or anything? Gaussian elimination will handle all the cases you can throw at it, but is slower than other methods which target specific cases. You could speed up gaussian elimination a little bit with strassen matrix multiplication, making it an O(n^ln(7)) algorithm. Unfortunetly it is really only good for square matrices.
The other thing is that do you really need the inverse? There are algorithms that will solve the equation Ax=b without ever finding the inverse of A. (e.g. conjugate gradients)
The only purpose of doing this is to practive my programming skills Hurkyl.
And dduardo, my knowledge about Linear Algebra is kinda limited.
My first impression was that if i found the algorithm for reduced row echelon form, i could use the algorithm easily to do the inverse algorithm as well since they are extermely close to each other.
Since i finished my exams and now i got some free time again, i will try to implement your algorithm on C++ code, and tell you guys what i came up with :).
Also, a recursive method of doing the task came to my mind, but i read the recursive functions are ineffecient, especially if the data inserted is huge...
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 69 ·
11K
