Renormalization group and cut-off
The discussion centers on the introduction of a cut-off in the action integral \(\int_{|p| \le \Lambda} \mathcal L (\phi, \partial _{\mu} \phi)\), which impacts the mass \(m(\Lambda)\), charge \(q(\Lambda)\), and Green functions \(G(x,x',\Lambda)\). The cut-off \(\Lambda\) is crucial as it defines the energy scale where new physics emerges, particularly in effective theories like the Fermi model of weak interactions. When energy approaches the mass of the W boson, the effective theory's expansion becomes inadequate, necessitating a more fundamental theory. This highlights the importance of the cut-off in maintaining well-defined physical quantities.
  • Understanding of quantum field theory concepts
  • Familiarity with effective field theories
  • Knowledge of renormalization techniques
  • Basic principles of particle physics, particularly the weak interaction
  • Study the implications of cut-off regularization in quantum field theories
  • Research the Fermi model of weak interactions and its limitations
  • Explore advanced renormalization group techniques and their applications
  • Investigate the relationship between effective theories and fundamental theories in particle physics
This discussion is beneficial for theoretical physicists, particularly those specializing in quantum field theory, particle physics researchers, and students exploring the concepts of renormalization and effective field theories.
Sangoku
Hi.. in what sense do you intrdouce the cut-off inside the action
[tex]\int_{|p| \le \Lambda} \mathcal L (\phi, \partial _{\mu} \phi )[/tex]
then all the quantities mass [tex]m(\Lambda)[/tex] charge [tex]q(\Lambda)[/tex] and Green function (every order 'n') [tex]G(x,x',\Lambda)[/tex]
will depend on the value of cut-off, and are well defined whereas this cut-off is finite now what else can be done ??.. could we consider this cut-off [tex]\Lambda[/tex] to be some kind of 'physical' field (or have at least a physical meaning, or can we make this finite measuring 'm' 'q' or similar
I am not sure I understand your question but the cutoff represents the energy scale at which new physics becomes important.
Consider for example the Fermi model of the weak interaction. It`s an effective theory which can be used as long as the energy of the reaction is below the mass of the W boson. So you could construct an effective theory and integrate up to the mass of the W and renormalize and you would get a well defined expansion of any observable. but of the energy gets close to the mass of the W, the expansion breaks down because an infinite number of terms would have to be taken into account, signaling the need to use a mre fundamental theory.
hope this helps
Patrick
  • · Replies 0 ·
