Thread Closed
Calculate initial diameter from longitudinal strain and final diameter
Share Thread Thread Tools
Aug21-07, 04:30 PM   #1
"Calculate the initial diameter of a wire that has been longitudinally strained by 30% and whose final diameter is 0.1cm. Assume no volume change."
Now I know that if there is no volume change, v=poisson's ratio= 0.5. Thus the lateral strain would equal 30%*0.5= 15%. But when I plug it into the strain equation and use a diameter of 0.1cm as the initial length, I get 0.1176. The answer is supposed to be 0.114cm.
Any thoughts?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Aug21-07, 04:36 PM   #2
Recognitions:
Homework Helper Homework Help
If there is no volume change you don't have to know about wires or poisson ratio.
It's just a simple geometry excercise
pi r1^2 L1 = pi r2^2 L2 and L2 = 1.3 L1 just rearrange in terms of r1
Aug21-07, 04:51 PM   #3
Wow I way over thought that one, thanks.
Thread Closed
Thread Tools
Similar Threads for: Calculate initial diameter from longitudinal strain and final diameter
Thread Forum Replies
calculate crater diameter Biology, Chemistry & Other Homework 0
finding diameter Introductory Physics Homework 1
Diameter of Hydrogen Advanced Physics Homework 13
shaft diameter Engineering, Comp Sci, & Technology Homework 1
wall thickness s = da=12 Engineering, Comp Sci, & Technology Homework 1
