Need some help interpreting the muon energy spectrum
  • Context: Graduate
  • Thread starter Thread starter stakhanov
    Energy Muon Spectrum
The discussion focuses on interpreting the muon energy spectrum at the Earth's surface, specifically the flux of muons as a function of energy and angle from the zenith. The Gaisser parametrization, dN/dE=f(theta,E), is used to model this flux. The integration of f(theta,E) over an energy range is necessary to determine the number of muons within that range, and the 'per GeV' unit indicates the density of muons per energy interval. Accurate calculations require integrating both over energy and angular ranges.
  • Understanding of cosmic ray physics
  • Familiarity with the Gaisser parametrization
  • Knowledge of integration techniques in physics
  • Basic concepts of muon detection and measurement
  • Study the Gaisser parametrization in detail
  • Learn about integration techniques for energy spectra
  • Explore the relationship between muon flux and angular dependence
  • Investigate Maxwell-Boltzmann distributions in particle physics
Physicists, researchers in cosmic ray studies, and students interested in particle physics and muon detection methodologies.
stakhanov
I have been looking at the flux of muons (as secondary cosmic ray particles) at the Earth's surface as a function of both energy and angle from the zenith. From what I have read, the flux follows a squared cos theta relationship with angle from the zenith and several attempts have been made to accurately parametrize the energy dependence. I am using a revision of the Gaisser parametrization, dN/dE=f(theta,E) [per square cm, per second, per steradian, per GeV]. My questions are as follows:
1. Do I just integrate f(theta,E) over an energy range to find the number of muons in that range? I have done this and it doesn't give what I expect (something that looks roughly like a Maxwell-Boltzmann spectrum in form) so I want to check I am doing the right thing.
2. How do I understand the 'per GeV' part of the untis of f(theta,E)? If for example, f(theta=10,E=20) = 2x10^-5, then it means that on average 2x10^-5 muons with energy 20GeV will flow through a square cm from a solid angle of 1 steradian centred around a point at 10 degrees from the zenith. Where does the 'per GeV' come into it?
Sorry if this doesn't make sense but I'd appreciate any help.
Thanks
stakhanov said:
I2. How do I understand the 'per GeV' part of the untis of f(theta,E)? If for example, f(theta=10,E=20) = 2x10^-5, then it means that on average 2x10^-5 muons with energy 20GeV will flow through a square cm from a solid angle of 1 steradian centred around a point at 10 degrees from the zenith.
No. It means that if you select only muons with energies from 19.5 to 20.5 GeV, that is, a range of 1.0 GeV, you will get approximately [itex](2 \times 10^{-5})(1.0) = 2 \times 10^{-5}[/itex] muons per steradian at 10 degrees. If you select only muons with energies from 19.95 to 20.05 GeV, that is, a range of 0.1 GeV, you will get approximately [itex](2 \times 10^{-5})(0.1) = 2 \times 10^{-6}[/itex] muons. And similarly for other energy ranges.
In general, this sort of calculation is only approximate. To get the exact number of muons in an energy range, you have to integrate over the desired energy range:
[tex]\int^{E_{max}}_{E_{min}} {f(\theta, E) dE}[/tex]
Of course, you also have to integrate over a suitable angular range as appropriate.
  • · Replies 0 ·
  • · Replies 0 ·
