Rotational Kinetic Energy: Multi-Axis Rotation of a Ball
The discussion revolves around the definition and calculation of rotational kinetic energy for a body, specifically a ball, that is rotating about multiple axes. Participants explore the implications of such multi-axis rotation on the overall kinetic energy, considering both rotational and translational components.
  • Some participants suggest that when a body rotates about more than one axis, the center of mass contributes to translational kinetic energy, while the rotational kinetic energy can be expressed using the formula 1/2 I ω², where I is the moment of inertia.
  • Others argue that the rotational kinetic energy must account for both rotations, indicating that the motion of each partial mass relative to the center of inertia is significant.
  • A participant mentions that the concept of "rotational" energy is most useful for extended bodies and can be treated as translational energy of the center of mass when necessary.
  • There is a suggestion that the Earth-Sun system may not serve as a suitable model for the described scenario due to differences in axis orientation.
  • One participant emphasizes that rotational kinetic energy is a mathematical convenience and can be derived from the kinetic energy of individual particles within the body.
  • Another participant asserts that a second rotation cannot occur unless referring to precession, implying limitations on the types of motion that can be considered.
Participants express differing views on how to define and calculate rotational kinetic energy in multi-axis scenarios. There is no consensus on the best approach or the implications of the various components involved.
Participants highlight the complexity of defining rotational kinetic energy when multiple axes are involved, noting that assumptions about the system's configuration and the nature of the axes can significantly affect the analysis.
pardesi
how do u define rotational kinetic energy when the body is rotting about more than one axis. as an example take a ball that ia rotaing about an axis passing through the centre of ineria whiloe the centre itself rotates in an axis perpendicular to this
the "centre itself" rotating about some other axis means that the center of mass is moving with some velocity which would not be put lumped into "rotational" kinetic energy, it's just translational kinetic energy of the whole sphere. Then the rotational kinetic energy is just given by the usual expression
[tex] 1/2 I \omega^2 [/tex]
where \omega is the angular velocity about the "axis passing through the centre of [inertia]" and I is 2/5 MR^2.
no but the actual answer includes both the rotation anyway but as the centre of amss rotates sbouta point so do the rest
what do you mean?--like the earth, for example (or specifically)?
i just wanted to know the definition of rotational kinetic energy when the body is rotating about two axes
rotation and precession?
yeah but that because, if I choose to, I can write
[tex] m v^2/2 + I \omega^2/2 = m R^2\Omega^2/2 + I\omega^2/2[/tex]
where [tex]\Omega[/tex] = v/R is the velocity (say, of the Earth around the sun) divided by the earth-sun distance... whereas [tex]\omega[/tex] is 2\pi/24 hr^-1. The concept of "rotational" energy is most useful when dealing with extended bodies, and I can treat the first term as as translational energy of the center of mass if I like. Which I can't do for the second term
(...) As an example take a ball that is rotating about an axis passing through the centre of inertia while the centre itself rotates in an axis perpendicular to this
I assume that the movement of each partial mass relative to the total centre of inertia must be taken into account. If that is true, then the Earth-Sun system, in which the axes are roughly parallel, might not be a suitable model for a system with perpendicular axes as described by the OP. A deeper analysis of the situation might prove me wrong, though.
If not, another parameter one could look into is whether the orientation of the rotational axis (contrasted to the orbital axis) is constant or conically symmetric. (I realize that a few terms used in this paragraph are slightly arbitrary, but I hope y'all know what I mean).
Just remember that rotational kinetic energy is simply kinetic energy, and that it's existence is a mathematical convenience. You can find the kinetic energy of a particle by the usual [tex]\frac{1}{2}mv^2[/tex]. All other bodies are considered to be composed of particles, and the K.E. of the entire body is just the sum of the particles. For a rigid body rotating about one axis without translation, there is a simple (ahem) formula that relates the distribution of mass (encoded in the moment of inertia), rotational angular velocity [tex]\omega[/tex] and the total K.E. By a stroke of good luck, rotation about a single axis with translation just involves adding up the "rotating bit" and the "linear bit". You should decompose the body and try to see if your "rotation about 2 axis" falls apart into easy bits. Define your situation exactly, and try the calculation. I'm sure the denizens here will be happy to lend a hand if you get stuck.
The second rotation can never take place. (Unless you mean precession).
If it could, gyroscopes would not work! They do, believe me.
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 77 ·
  • · Replies 32 ·
  • · Replies 60 ·
  • · Replies 19 ·
