Glass refractive index vs wavelength, exceptions?
Normal glasses exhibit a higher refractive index for blue light compared to red light. However, certain specialized glasses and minerals can display anomalous dispersion, where shorter wavelengths have a lower refractive index. This phenomenon can occur due to absorption peaks in the glass or the material's overall dispersion characteristics. For instance, silica has a zero-dispersion wavelength of 1.55 microns, which is critical for telecommunications in optical fibers.
  • Understanding of refractive index and its significance in optics
  • Knowledge of dispersion phenomena in materials
  • Familiarity with optical fiber technology and its applications
  • Basic concepts of glass composition and doping techniques
  • Research the effects of doping on glass properties and refractive index
  • Explore the concept of anomalous dispersion in different materials
  • Study the applications of zero-dispersion wavelength in optical communications
  • Investigate various types of specialized glasses used in optics
Optical engineers, materials scientists, and professionals in telecommunications seeking to deepen their understanding of glass properties and their applications in optical systems.
lalbatros
Normal glasses have a larger refractive index for blue than for red.
Are there special glasses that differ in this respect?
Or maybe are there some minerals that behave differently, still being transparent in the visible spectrum and colorless?
Thanks to tell me if you know something about that.
Science news on Phys.org
There are two manifestations of anomalous dispersion (short wavelengths having lower n) in glass. The first manifestation is due to absorption peaks in the glass. Near the short wavelength side of an absorption peak, dispersion will be anomalous. Glasses can be doped to control at what wavelength ranges anomalous dispersion will occur. The second manifestation is due to the overall material dispersion in the glass. Glasses possesses a characteristic wavelength where the dispersion in the glass is zero. Above this characteristic wavelength, normal dispersion (short wavelengths having high n) prevails, below this wavelength, anomalous dispersion is predominant. In silica for example, the zero-dispersion wavelength is 1.55 microns - which is why telecommunications networks primarily use this wavelength range for signal transmission in optic fibres.
Claude.
Thanks a lot Claude.
Very instructive answer.
10K
  • · Replies 207 ·
16K
  • · Replies 16 ·
20K
