Analyzing a Wave: Homework Solutions
  • Thread starter Thread starter aliaze1
    Wave
The discussion revolves around analyzing a wave, specifically focusing on the relationships between wave properties such as velocity, tension, and displacement. The original poster presents equations related to wave mechanics and describes their attempts to solve a problem involving these concepts.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the calculation of wave speed and its relationship to tension. Questions arise regarding whether the problem is asking for wave velocity or lateral velocity of a point on the string. There is also discussion about unit consistency and its impact on the calculations.
Participants are actively engaging with the problem, questioning assumptions about the requirements of the questions and discussing potential errors in calculations. Some guidance has been offered regarding unit consistency, which may help clarify discrepancies in the results.
There are indications of confusion regarding the units used for linear mass density and tension, as well as the interpretation of the problem's requirements. The original poster notes that the third part of the problem may not be necessary for solving the first part.
aliaze1
http://photo.ringo.com/230/230997145O975467146.jpg
λ=v/f
k=2π/λ
ω=2πf
T=1/f
v=ω/k
V(string) = √(Tension of string/μ), where μ = denisty
D(x,t) = A sin (kx - ωt + Φ)
I found the maximum displacement as 2, found from the given equation
The third part seemed to be the next simplest, so using v=ω/k, I calculated 638/12.57 as the speed, which was incorrect
To my knowledge, this speed is needed to calculate the tension of part 1
i guess it is possible, but that is the exact question copied word-for-word
what does d(D(x,y))/dt means?
I just realized that the third part is not required to complete the first part,
using v=ω/k, and plugging this v into
V(string) = √(Tension of string/μ), where μ = denisty;
I get an answer of 12880.7, which is essentially 12.9 *103...the answer however is simply 12.9...
where am i going wrong?
thanks
I thought it had to do with the amplitude being in centimeters, so I divided by 100, but that still is 129 not 12.9...
Make sure all units are consistent. The linear mass density is 5 g/ m as opposed to 0.05 g /cm or 0.005 kg/m. Perhaps that is where one is off by 3 or 1 order of magnitude depending on the values one uses. Tension should be in Newtons (for SI/mks).
thanks!, makes sense
10K
