How can effervescent waves be used for superlensing?
  • Thread starter Thread starter sas3
The discussion revolves around the concept of effervescent waves and their potential application in superlensing, particularly in the context of focusing light beyond its wavelength. Participants explore the implications of this phenomenon, its theoretical underpinnings, and possible applications in various fields.
  • Experimental/applied
  • Some participants express confusion regarding the possibility of focusing light smaller than its own wavelength, questioning the duality of light and the nature of photons in this context.
  • Others propose that if light can be focused beyond its wavelength, it could lead to significant applications, although the feasibility of such techniques remains uncertain.
  • One participant clarifies that the wavelength of light is not indicative of the size of photons, using an analogy to explain the relationship between wavelength and frequency.
  • Another participant introduces the concept that effervescent waves can create smaller wavelengths in the medium they interact with, suggesting that this is the wave being focused rather than the light itself.
  • Concerns are raised about the scalability of these techniques for applications such as harnessing sunlight or improving telescope resolution, with skepticism about whether the nature of light would allow for such advancements.
  • A participant describes a specific application of effervescent waves in sensors, detailing how they can be used to excite dye molecules in a biological coating without the laser light interfering with the detection process.
Participants generally express confusion and curiosity about the concepts discussed, with no clear consensus on the feasibility or implications of using effervescent waves for superlensing. Multiple competing views and uncertainties remain regarding the nature of light and the practical applications of these waves.
Participants highlight limitations in understanding the duality of light and the specific conditions under which effervescent waves operate, including their short penetration lengths and exponential decay. These factors may influence the applicability of the discussed techniques.
sas3
I don’t know if anyone else here seen the article but I found it very interesting.
Although I am a little confused or maybe I just do not understand the duality of light very well.
I did not think it was possible to focus light smaller then its own wavelength.
Maybe someone here can explain this to me.
Here is a link to the article.
http://blogs.zdnet.com/emergingtech/?p=632
Computer science news on Phys.org
This sounds like a really interesting concept. If you could focus a laser down past the wavelength of the wave, then a lot of applications could come from this.
"If you could focus a laser down past the wavelength of the wave"
That is the part I am confused about how can you make a wave smaller then the wavelength?
Is the stuff coming out still photons or is it something else?
The wavelength isn't really the size of the photon - it's just another way of stating it's frequency. Imagine watching a ball bounce up and down as it goes along a road, if it moving along at 2m/s and is bouncing once per second it's 'wavelength' is 2m but the ball is much smaller than this.
Also this technique isn't focussing the light. There is an odd effect where light reflecting off a surface creates a wave in the surface with a much smaller wavelength than the light producing it. It is this wave which is being focussed.
Intriguing. I wonder what scales this will work over. They mentioned optical storage and nanolithography, but would it 'scale up' for harnessing sunlight more efficiently or improving telescope resolution? I figure not the latter, because it changes the nature of the light; an image probably wouldn't survive the transisition.
Effervescent waves have very small penetration lengths ( order of nm ) and decay exponentially. This is their main use in sensors.
You coat a mirror with some biological goop with dye molecules on the interesting bit, you bounce a laser off the back of the mirror, the effervescent wave penetrates a couple of nm out into the goop and excites the dyes which fluoresce and you pick that up with a detector. But since the laser was only ever on the back side of the mirror none of the laser light reaches the detector which is the normal problem with excited dye setups.
This also relies on the very short length of the effervescent wave to only excite dye very close to the surface so you can use it to sample stuff in a liquid or gas volume with very little background - my wife's PhD was on this!
  • · Replies 29 ·
  • · Replies 38 ·
  • · Replies 36 ·
10K
  • · Replies 78 ·
