How Does Coil Dimension Affect Magnetic Field Strength?
The discussion revolves around the relationship between coil dimensions and magnetic field strength, specifically focusing on a coil made from copper wire with given resistance and dimensions, connected to a voltage source. Participants are exploring how these factors influence the magnetic field at the center of the coil.
  • Participants are attempting to relate the coil's length and number of turns to the magnetic field strength. There is a discussion about the implications of changing coil dimensions on resistance and current, and how that affects the magnetic field.
The discussion is ongoing, with participants providing insights and questioning the assumptions related to the problem setup. Some guidance has been offered regarding the relationship between the number of turns and coil length, but no consensus has been reached on the uniqueness of the solution.
There are considerations regarding the impact of coil length on resistance and current, and how these factors interplay with the magnetic field strength. Participants are also questioning whether the problem was stated completely and accurately.
gamesandmore
A piece of copper wire has a resistance per unit length of 6.40e-3 ohm/m. The wire is wound into a thin, flat coil of many turns that has a radius of 0.190 m. The ends of the wire are connected to a 12.0 V battery. Find the magnetic field strength at the center of the coil.
R/L = 6.40e-3 ohm/m
r = 0.190 m
V = 12.0 V
u0 = 4pi e -7 Tm/A
B = ? T
Equations:
V = IR (I = V/R)
B = u0 * n * I
so B = u0 * n * (V/R)
I don't know where to go from here.
Start by finding L in terms of n. That may be your missing ingredient.
n = turns/L
L = R/6.40e-3 ?
im lost here
Did you post the question exactly?
What I'm thinking is... can't you arbitrarily make the coil longer, keeping the number of turns/unit length the same... but increasing the resistance... thereby lowering the current. And that would lower the magnetic field?
So is there a unique solution to this problem?
