Calculating Total Current Draw for a Heat Pump on a 240v Power Line
  • Thread starter Thread starter niko
    Electricity
The total current draw for a heat pump connected to a 240V, 60Hz power line can be calculated by analyzing both the compressor and the backup strip heater. The compressor operates at 34 amperes with a power factor of 70%, resulting in a real current of 23.8 amperes and a reactive current of 14.4 amperes. The backup strip heater, rated at 10kW, draws 41.67 amperes. The total current draw when both systems operate simultaneously is calculated using the formula: Total = √(real^2 + reactive^2), yielding a total current draw of approximately 47.4 amperes.
  • Understanding of electrical concepts such as current, voltage, and power factor.
  • Familiarity with the calculation of real and reactive power in AC circuits.
  • Knowledge of the formula for calculating total current draw in parallel systems.
  • Basic understanding of heat pump operation and electrical ratings.
  • Study the principles of power factor correction in HVAC systems.
  • Learn how to calculate real and reactive power in AC circuits.
  • Research the specifications and operational characteristics of heat pumps.
  • Explore methods for measuring and optimizing electrical load in residential systems.
Electrical engineers, HVAC technicians, and anyone involved in the design or maintenance of heating systems will benefit from this discussion.
niko
a heat pump is connected to a 240v, 60hz power line. the compressor has a current draw of 34 amperes when operating. the compressor has a power factor of 70%. the back up strip heat is rated at 10kw. what is the total current draw that will occur if the strip heat comes on while the compressor is operating
Break the compressor current into real and reactive parts. Calculate the current of the strip heater (real). Add the real parts. Total = square root (real^2 + reactive^2)
  • · Replies 23 ·
