Register to reply
Ball being thrown against a wall
by turnip
Tags: ball, thrown, wall
Share this thread:
turnip
#1
Sep29-07, 08:20 PM
P: 31
a 120kg ball moving at 18m/s strikes a wall perpendicularly and rebounds straight back at 12m/s. after the initial contact, the centre of the ball moves 0.27cm closer to the wall. Assuming uniform deceleration, show that the time of the contact is 0.00075s. How large an average forced does the ball exert on the wall?
i figure that:
m=.12
u= 18
v=12
s1 - s2 = 0.0027
s1 = s2 + 0.0027
2. Relevant equations
f= delta p/t
= mv-mu/t
s=ut+1/2at(squared)
p=mv
3. The attempt at a solution
what threw me off is the the time, i can get the average force no problem after i have the time.
my question is do i put the time (0.00075) into the equation s=ut+1/2at(squared), because i have done that which worked out wrong.
or
do i rearrange and substitute some other formulas? if i dont have any formulas needed please tell me!
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
rootX
#2
Sep29-07, 08:24 PM
rootX's Avatar
P: 1,294
Try work energy theorem here.
Fd = change in Ek
rootX
#3
Sep29-07, 08:26 PM
rootX's Avatar
P: 1,294
Trying one way I get this ridiculously large # for force: 7 x 10^6 N
I assumed that it took 0.27 cm to stop the ball from speed of 18 m/s
turnip
#4
Sep30-07, 04:25 AM
P: 31
thank you for trying, but the way i read it, the actual displacement is unknown
you see the ball hits the wall starting at displacement = x
after it rebounds off the wall it is .27 cm closer from its original starting point of x
therefore it is: displacement after rebound = x - .27 cm
anymore ideas anyone?
learningphysics
#5
Sep30-07, 04:35 AM
HW Helper
P: 4,124
To get the time, you need to divide the problem into two parts... first find the time it takes to be brought to 0m/s from 18m/s... then find the time it takes to go from 0m/s up to 12m/s.
I get the given time of 0.00075s.
For the second part, Faverage*time = change in momentum. (oops nevermind, I just saw that you got this part).
learningphysics
#6
Sep30-07, 04:46 AM
HW Helper
P: 4,124
The trick to this problem is that the accelerations for the two parts are not the same... ie: the deceleration from 18m/s to 0m/s is different from the acceleration from 0m/s to 12m/s.
turnip
#7
Sep30-07, 08:58 PM
P: 31
Quote Quote by learningphysics View Post
okay i get that, but could you please explain how you algebraically got the acceleration becuase i can only think of f=ma and a = v-u/t but both have two variables!
if you could please explain the acceleration i will be right from there thanks :)
learningphysics
#8
Sep30-07, 11:51 PM
HW Helper
P: 4,124
Quote Quote by turnip View Post
well, you don't need acceleration... you need time:
so for the first part:
d = (v1 + v2)/2 * t
0.0027 = (18 + 0)/2 * t
solve for t
get t = 0.0003s
do the same thing for the second part... v1 = 0 v2 = 12.
if you want to get acceleration (you don't need to get it)
use v2^2 = v1^2 + 2ad.
turnip
#9
Oct1-07, 03:01 AM
P: 31
right. just one more thing i dont get:
d = (v1 + v2)/2 * t
i understand the formula, but whats with the /2 part of it?
is that to get the average velocity?
learningphysics
#10
Oct1-07, 03:06 AM
HW Helper
P: 4,124
d = (v1 + v2)/2 * t
yes. distance = average velocity * time. [tex]d = \frac{(v1+v2)}{2}*t[/tex]
turnip
#11
Oct1-07, 03:13 AM
P: 31
thanks that was very clearly explained :)
Register to reply
Related Discussions
A ball is thrown... Introductory Physics Homework 2
A rubber ball thrown to a wall Classical Physics 28
Ball thrown upward Introductory Physics Homework 26
Kinematics- ball thrown Introductory Physics Homework 3
Ball thrown from building Introductory Physics Homework 5
