How to solve the equation 3^2x+1 = 3^x + 24, do I need logarithms
  • Thread starter Thread starter repugno
    Logarithms
The discussion revolves around solving the equation 3^(2x+1) = 3^x + 24, with participants exploring the use of logarithms and various algebraic manipulations to find a solution.
  • The original poster attempts to solve the equation using logarithms but expresses uncertainty about the initial steps. Other participants question the notation and clarify the properties of logarithms, particularly regarding the incorrect application of log(a + b).
Participants are actively engaging with the problem, providing feedback on each other's attempts and clarifying misunderstandings. Some have suggested alternative approaches, such as changing the base of the logarithm, which appears to have helped one participant progress.
There is a mention of potential confusion due to notation and the original equation's structure, which may affect participants' understanding and approach to solving the problem.
repugno
Greetings all, I have a slight problem solving this equation ... 3^2x+1 = 3^x + 24
I know I can solve it with logs but I'm just not sure where to begin. I have tried taking logarithms both sides but it didn't work :confused:
Perhaps someone could give me a clue :biggrin:
thanks
Can you show the work you've done so far?
cookiemonster
Sure...
3^2x+1 = 3^x + 24
(2x+1)lg3 = xlg3 + lg24
(2x+1)lg3/lg3 = xlg3/lg3 + lg24/lg3
2x+1 = x + 2.89
x = 1.89
This is obviously wrong.
Be careful with log (3^x + 24).
In general, log(a + b) does not equal log(a) + log(b).
And you need to be careful with your notation. I first read the problem as 3^(2x) + 1 = 3^x + 24. Those darned parentheses!
cookiemonster
32x+1 = 3x + 24
Can you show that 32x+1 = 3*32x? Can you show that 3*(32x) = 3*(3x)2? Now what kind of equation do you get if you let t = 3x?
Thank you very much for your help.
These logarithms is not my good friend unfortunitaly, it is either that or I'm missing a fundamental point.
[itex]log_3x - 2log_x3 = 1[/itex]
I don't understand how to solve this, I know the rules of logarithms but they don't seem to be much help here. Can anyone help me please.
Thanks
You might find this useful
[tex]\log_b a = \frac{\ln a}{\ln b}[/tex]
cookiemonster
More generally:
[tex]\log_b a = \frac{\log_c a}{\log_c b}[/tex]
Where c is whatever number you want (cookiemonster chose c = e, resulting in natural logs). For the problem above you might want to pick c = 3.
It worked ! Thanks for the help yet again. One question though, how did you come to the conclusion that I should take the base as 3?
You started with this:
Using ln you would have gotten:
[itex]\frac{\ln x}{\ln 3} - 2\frac{\ln 3}{\ln x} = 1[/itex]
And just get stuck with ln(3). However, using 3 as the base you can get:
[itex]\frac{\log_3 x}{\log_3 3} - 2\frac{\log_3 3}{\log_3 x} = 1[/itex]
And of course log3(3) = 1 and it's much easier to handle:
[itex]\log_3 x - \frac{2}{\log_3 x} = 1[/itex]
Obviously you would still get the same answer with both methods, I just thought it would be slightly easier to solve when using base 3. :smile:
